I don’t know why I get an error when I call a function.
Just put ‘LCD12864 init();’ comment it out, and it will compile normally.
Please help to answer, thank you.
error message
c:/users/xiang/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio\build\uno_r4_wifi\src\main.cpp.o: in function `loop':
main.cpp:(.text.loop+0x0): undefined reference to `LCD12864_init()'
*** [.pio\build\uno_r4_wifi\firmware.elf] Error 1
lcd12864.c
#include "lcd12864.h"
//写cmd函数
void LCD12864_write_cmd(int cmd){
digitalWrite(LCD12864_RS,LOW);
digitalWrite(LCD12864_RW,LOW);
digitalWrite(LCD12864_EN,LOW);
//缺少数据的输出定义cmd
delay(1000);
digitalWrite(LCD12864_EN,HIGH);
delay(1000);
//写data函数
void LCD12864_write_data(int data){
digitalWrite(LCD12864_RS,HIGH);
//缺少数据的输出定义data
delay(1000);
delay(1000);
//显示屏初始化函数
void LCD12864_init(void){
digitalWrite(LCD12864_PSB,HIGH);
//控制指令
LCD12864_write_cmd(0X30);//功能设定 001DL X0/REXX
LCD12864_write_cmd(0X0C);//显示状态开关 00001DCB
LCD12864_write_cmd(0X06);//进入设定点 000001 1/D S
LCD12864_write_cmd(0X31);//清屏
void LCD12864_clear(void){
void LCD12864_show_string(int x,int y,char *str){
if(y<=0){
y=0;
if(y>3){
y=3;
x&=0x0f;
//直接显示的地址
switch (y)
case 0:x|=0x80;break;
case 1:x|=0x90;break;
case 2:x|=0x88;break;
case 3:x|=0x98;break;
LCD12864_write_cmd(x);
while (*str!='\0')
LCD12864_write_data(*str);
str++;
lcd12864.h
#ifndef _lcd12864_H
#define _lcd12864_H
#include<Arduino.h>
const int LCD12864_RS = 8;
const int LCD12864_RW = 9;
const int LCD12864_EN = 10;
const int LCD12864_PSB = 12; //高电平为8位
//缺少0~7端口的定义 对应数据口的定义data
// Declare Functions
void LCD12864_init();
void LCD12864_clear(void);
void LCD12864_show_string(int x,int y,char *str);
main.cpp
pinMode(LCD12864_RS,OUTPUT);
pinMode(LCD12864_RW,OUTPUT);
pinMode(LCD12864_EN,OUTPUT);
pinMode(LCD12864_PSB,OUTPUT);
LCD12864_init();
//LCD12864_show_string(0,0,"Hello World");
