Hi everyone,
I’m trying to use libwebp library in my Arduino project to decode animated webp images.
At the moment the sketch is pretty basic, as I removed everything but the webp part.
I’m getting this error during linking:
Compiling .pio/build/webp/src/main.cpp.o
Linking .pio/build/webp/firmware.elf
.pio/build/webp/src/main.cpp.o:(.literal._Z8testWebpv+0x4): undefined reference to `WebPAnimDecoderOptionsInitInternal'
.pio/build/webp/src/main.cpp.o:(.literal._Z8testWebpv+0x8): undefined reference to `WebPAnimDecoderNewInternal'
.pio/build/webp/src/main.cpp.o:(.literal._Z8testWebpv+0xc): undefined reference to `WebPAnimDecoderGetInfo'
.pio/build/webp/src/main.cpp.o:(.literal._Z8testWebpv+0x10): undefined reference to `WebPAnimDecoderHasMoreFrames'
.pio/build/webp/src/main.cpp.o:(.literal._Z8testWebpv+0x14): undefined reference to `WebPAnimDecoderGetNext'
.pio/build/webp/src/main.cpp.o:(.literal._Z8testWebpv+0x18): undefined reference to `WebPAnimDecoderReset'
.pio/build/webp/src/main.cpp.o:(.literal._Z8testWebpv+0x1c): undefined reference to `WebPAnimDecoderDelete'
.pio/build/webp/src/main.cpp.o: In function `testWebp()':
/Users/carlos/projects/esp32/test-webp/src/main.cpp:27: undefined reference to `WebPAnimDecoderOptionsInitInternal'
/Users/carlos/projects/esp32/test-webp/src/main.cpp:27: undefined reference to `WebPAnimDecoderNewInternal'
/Users/carlos/projects/esp32/test-webp/src/main.cpp:27: undefined reference to `WebPAnimDecoderGetInfo'
/Users/carlos/projects/esp32/test-webp/src/main.cpp:27: undefined reference to `WebPAnimDecoderHasMoreFrames'
/Users/carlos/projects/esp32/test-webp/src/main.cpp:27: undefined reference to `WebPAnimDecoderGetNext'
/Users/carlos/projects/esp32/test-webp/src/main.cpp:27: undefined reference to `WebPAnimDecoderReset'
/Users/carlos/projects/esp32/test-webp/src/main.cpp:27: undefined reference to `WebPAnimDecoderDelete'
*** [.pio/build/webp/firmware.elf] Error 1
main.cpp (based on webp2gif) tool:
#include <webp/demux.h>
void testwebp();
void setup(){
delay(1000);
Serial.println("Setting up...");
delay(5000);
testwebp();
void testwebp() {
WebPAnimDecoderOptions webp_dec_options;
WebPAnimDecoderOptionsInit(&webp_dec_options);
webp_dec_options.color_mode = MODE_RGBA;
webp_dec_options.use_threads = true;
WebPData webp_data;
webp_data.size = 1024;
webp_data.bytes = new uint8_t[webp_data.size];
WebPAnimDecoder* webp_dec = WebPAnimDecoderNew(&webp_data, &webp_dec_options);
WebPAnimInfo webp_anim_info;
WebPAnimDecoderGetInfo(webp_dec, &webp_anim_info);
int curr_timestamp = 0;
// int prev_timestamp = 0;
while(WebPAnimDecoderHasMoreFrames(webp_dec)){
uint8_t* rgba_buffer;
WebPAnimDecoderGetNext(webp_dec, &rgba_buffer, &curr_timestamp);
printf("test\n");
// prev_timestamp = curr_timestamp;
WebPAnimDecoderReset(webp_dec);
WebPAnimDecoderDelete(webp_dec);
my directory structure looks like:
test-webp
├── .pio
├── include
│ └── README
├── lib
│ ├── README
│ └── libwebp
│ ├── library.json
│ └── src
│ ├── Makefile.am
│ ├── dec
│ ├── demux
│ ├── dsp
│ ├── enc
│ ├── libwebp.pc.in
│ ├── libwebp.rc
│ ├── libwebpdecoder.pc.in
│ ├── libwebpdecoder.rc
│ ├── mux
│ ├── utils
│ └── webp
├── platformio.ini
├── src
│ └── main.cpp
lib/libwebp/library.json:
"name": "libwebp",
"build": {
"srcFilter": [
"+<src/**/*.c>"
"unflags": [
"-DHAVE_CONFIG_H"
platformio.ini:
[env:webp]
board = esp32doit-devkit-v1
upload_port = /dev/cu.SLAB_USBtoUART
I’m running Visual Studio Code v1.55.2, running on MacOS Mojave, and PlatformIO Core v5.1.1.
I guess it’s not finding the definition of those functions, but I’m not sure what I should add/change to make it work.
Any suggestions would be much appreciated.
Thanks!
