I have to create three projects that share some code and I’d like create this kind of folders structure:
c:\projects\common
|–routines.h
|–routines.cpp
|–<other_common_files>
c:\projects\project1
|–src
|–main.cpp
|–lib
|–<pio_structure>
c:\projects\project2
|–src
|–main.cpp
|–lib
|–<pio_structure>
c:\projects\project3
|–src
|–main.cpp
|–lib
|–<pio_structure>
-platformio.ini code
[env:esp12e]
platform = espressif8266
board = esp12e
-I…/common
-routines.h code
#ifndef routines_h
#define routines_h
extern bool test;
-routines.cpp code
#ifndef routines_cpp
#define routines_cpp
#include <routines.h>
bool test = true;
-main.cpp code
test = true;
I’d like all three projects can use routines definited in .h and written in .cpp, but linker give me this error: .pio/build/esp12e/src/main.cpp.o:(.text.setup+0x0): undefined reference to `test’
What’s wrong?
Best regards
- Why do you have an include-guard in a source-file? You normally only use those in header-files.
- When using
#include
using #include <foo.h>
is used to include system libraries/header-files while you should use #include "bar.h"
to include your own header-files/libraries.
I inserted include-guard block only because of inexperience!
Now I include like you show, but I have same error.
With build_flags = -I…/common pio knows where are my own .h files but not .cpp (same folder).
If I put the .cpp files in the src folder, pio finds them, but I would not put them in src folder, but only in my own “common”, shared for all my projects.
Is there a way to instruct pio to “see” my .cpp files in “common” folder, for example, like a build_flags?
Oh I completely overlooked your project structure. Your “common” folders basically is like your directory of a few custom libraries multiple projects depend on. Therefor you will need to tell your project’s platformio.ini
-file where to find those libraries so PIO’s LDF can handle them. Take a look here: Library Dependency Finder (LDF) — PlatformIO latest documentation
So instead of using build flags you probably should use the lib_extra_dirs
option and set that to your common-libraries folder.
I read documentations about ldf, I created a new folder called “cpp” with my cpp files under “common”, I added lib_extra_dirs in the platformio.ini with the relative path, but I have the same error
Try with a proper library folder structure… i.e. the lib_extra_dirs
would point to the \common
folder, which then contains routines
, lib2
, lib3
etc, which then contain the .h
and .cpp
for each of the project libraries…
Or I could be completely wrong… I took the cowards way out for ‘common libraries’ and used git submodules
