I’m just starting into a new project which has to be highly configurable for lots of different hardware so I am building up an organization of configuration.h + folders,+ driver files. To do this, I am starting with a “blinking LED” program, but breaking everything out to include a main.cpp, configuration.h, includes.h, init.c, and heartBeat.c. Everything goes fine until I break the flashing LED code into heartBeat.c. The error does not appear until the linking part of the build.
c:/users/peted/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\um_feathers3\src\main.cpp.o:(.literal._Z4loopv+0x0): undefined reference to `heartBeat()'
c:/users/peted/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\um_feathers3\src\main.cpp.o: in function `loop()':
C:\Users\peted\OneDrive\Documents\PlatformIO\Projects\Feather3Test/src/main.cpp:15: undefined reference to `heartBeat()'
*** [.pio\build\um_feathers3\firmware.elf] Error 1
heartBeat.c and heartBeat.h live in the src/utils directory but I get the same error even if they are in the src directory along with all the other code files.
I know this is a complex structure for just a flashing LED program but it is as simple an example of the structure I am trying to set up for a much more complex program.
WHY DO I GET THIS ERROR AT LINK TIME? Many thanks for helping me get over the hump here.
so here is are the relevant files…
includes.h:
#ifndef _INCLUDES_H_
#define _INCLUDES_H_
#include "configuration.h"
#include "init.h"
#include "heartBeat.h"
#endif // _INCLUDES_H_
configuration.h
#ifndef _CONFIGURATION_H_
#define _CONFIGURATION_H_
#define FLASHING_LED
#endif // _CONFIGURATION_H_
main.cpp
#include <includes.h>
void setup()
init();
Serial.begin();
void loop()
#ifdef FLASHING_LED
heartBeat();
heartBeat.h
#ifndef _HEARTBEAT_H_
#define _HEARTBEAT_H_
#ifdef FLASHING_LED
void heartBeat(void);
#endif // _HEARTBEAT_H_
heartBeat.c
#include "includes.h"
#ifdef FLASHING_LED
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(500); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
delay(1000); // wait for a second
platformio.ini:
[env:um_feathers3]
board = um_feathers3
upload_port = COM6
src_dir = ./src
build_flags = -fmax-errors=5
-I./src/
-I./src/utils/
lib_ldf_mode = deep
lib_extra_dirs = ~/Documents/Arduino/libraries
and just to be complete…
init.h:
#ifndef _INIT_H_
#define _INIT_H_
void init (void);
#endif //_INIT_H_
init.c:
void init(void)
#ifdef FLASHING_LED
pinMode(LED_BUILTIN, OUTPUT);
