Undefined 'platformio' when starting debugger
I am trying to debug an ESP32 project. It’s worked in the past. But now when I try to run it in the debugger, I get the following in the Debug Console:
undefined 'platformio' is not recognized as an internal or external command, operable program or batch file.
The program will flash and run, but I can’t use the debugger.
Thanks,
Bob
Please add ‘C:\Users\Administrator.platformio\penv\Scripts’ to the system environment variable ‘path’ and verify if it is valid. Restart vscode before re debugging.
