I’ve been trying to use c++17 structured bindings in an arduino project, however it doesn’t compile.
I have set build_flags and build_unflags.
However the even weirder problem is this.
I did pio run with the verbose flag.
And i ran the command used compile the unit seperately. It compiled the unit successfully. So it is some platformio enviorment variable thats causing the problem.
Does avr-gcc even support this feature? I wasn’t to check this with some googling.
Thanks for taking a look at this.
I tried adding an ‘advanced scripting’ to dump the env.
Import("env")
# access to global construction environment
print(env)
# Dump construction environment (for debug purpose)
print(env.Dump())
But i didnt find anything that seemed useful.
Full dump here: as a comment
Architecture:
OS: Arch Linux x86_64
Host: Swift SF315-52 V1.07
Kernel: 5.8.14-arch1-1
% avr-g++ --version
avr-g++ (GCC) 10.2.0
Copyright (C) 2020 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
% pio --version
PlatformIO, version 5.0.1
% cat platformio.ini
[platformio]
[env]
board = megaatmega2560
src_filter = +<*.cpp> +<*.cc> +<*.c> -<mains/*>
[env:struct_bind_test]
src_filter = -<*> +<mains/struct_binding_test.cc>
build_unflags =
-std=gnu++11
-std=c++17
-std=gnu++17
% cat ./src/mains/struct_binding_test.cc
struct ret_type {
bool a;
unsigned long b;
ret_type get_val() {
return {true, 100};
void setup() {}
auto[x, y] = get_val();
– div ----
% pio run -e "struct_bind_test"
Processing struct_bind_test (platform: atmelavr; board: megaatmega2560; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (2.2.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
- framework-arduino-avr 5.0.0
Found 5 compatible libraries
Compiling .pio/build/struct_bind_test/src/mains/struct_binding_test.cc.o
src/mains/struct_binding_test.cc: In function 'void loop()':
src/mains/struct_binding_test.cc:15:9: error: expected unqualified-id before '[' token
Compiling [.pio/build/struct_bind_test/src/mains/struct_binding_test.cc.o] Error 1
====================================== [FAILED] Took 0.54 seconds ======================================
Environment Status Duration
struct_bind_test FAILED 00:00:00.539
================================= 1 failed, 0 succeeded in 00:00:00.539 =================================
% pio run -e "struct_bind_test" -v
Processing struct_bind_test (src_filter: -<*> +<mains/struct_binding_test.cc>; build_unflags: -std=gnu++11; build_flags: -std=c++17, -std=gnu++17; platform: atmelavr; board: megaatmega2560; framework: arduino)
avr-g++ -o .pio/build/struct_bind_test/src/mains/struct_binding_test.cc.o -c -std=c++17 -std=gnu++17 -fno-exceptions -fno-threadsafe-statics -fpermissive -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega2560 -DPLATFORMIO=50001 -DARDUINO_AVR_MEGA2560 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -Iinclude -Isrc -I~/.platformio/packages/framework-arduino-avr/cores/arduino -I~/.platformio/packages/framework-arduino-avr/variants/mega src/mains/struct_binding_test.cc
~/.platformio/packages/framework-arduisrc/mains/struct_binding_test.cc: In function 'void loop()':
n auto[x, y] = get_val();
steer_p IGNORED
remote_control IGNORED
serial_passthrough IGNORED
http_server IGNORED
AT_rewrite IGNORED
struct_bind_test FAILED 00:00:00.538
================================= 1 failed, 0 succeeded in 00:00:00.538 =================================
% avr-g++ -o .pio/build/struct_bind_test/src/mains/struct_binding_test.cc.o -c -std=c++17 -std=gnu++17 -fno-exceptions -fno-threadsafe-statics -fpermissive -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega2560 -DPLATFORMIO=50001 -DARDUINO_AVR_MEGA2560 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -Iinclude -Isrc -I~/.platformio/packages/framework-arduino-avr/cores/arduino -I~/.platformio/packages/framework-arduino-avr/variants/mega src/mains/struct_binding_test.cc
src/mains/struct_binding_test.cc:15:9: warning: structured binding declaration set but not used [-Wunused-but-set-variable]
15 | auto[x, y] = get_val();
