I am attempting to start developing with the ST Nucleo F767 board. As a start I thought I would duplicate the steps outlined in the PlatformIO tutorial for the Nucleo F401RE board which worked fine for me. I made the necessary changes to the main.h file to include the correct stmf32f7xx.h file and revised the LED pin/port definitions. It compiles fine but I get the following error when I try to upload the code:
Uploading .pio\build\nucleo_f767zi\firmware.elf
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
Error: read version failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
I am running under Windows.
Any suggestions would be appreciated.
