Hello! I recently posted about my now-resolved problems using the Atmel-ICE programmer with PIO here .
Now, I want to use and configure the same functional platformio.ini file to program the ATtiny814, which is the first time I’ll be using. (here is its PIO page).
When I try to upload, I get a weird error telling me my avr.conf file has a syntax error. This sounds like the platform I needed to install for this chip, atmelmegaavr, could be competing with the previously installed atmelavr ?
I found this post which discusses a similar error but the proposed solution does not work for me.
Here is the error I get:
AVAILABLE: custom
CURRENT: upload_protocol = custom
Uploading .pio\build\face\firmware.hex
avrdude error: syntax error [C:\Users\jcbsk\.platformio\packages\tool-avrdude\avrdude.conf:423]
avrdude error: unable to process system wide configuration file C:\Users\jcbsk\.platformio\packages\tool-avrdude\avrdude.conf
Here is the contents of avrdude.conf:
# Overall avrdude defaults; suitable for ~/.config/avrdude/avrdude.rc
default_parallel = "/dev/parport0";
default_serial = "/dev/ttyS0";
default_spi = "";
# default_bitclock = 2.5;
default_linuxgpio = "gpiochip0"; # This is line 423 which causes an error
allow_subshells = no;
Here is my .ini file, with adjustments for the t814 chip.
[env:face]
platform = atmelmegaavr ; this line was modified for t814
board = ATtiny814 ; this line was modified for t814
board_build.mcu = attiny814 ; this line was added for t814
board_build.f_cpu = 8000000L
board_fuses.hfuse = 0xDF ;smallest flash section size 256 since not using a BSL w/ Atmel-ICE
board_fuses.lfuse = 0xE2 ;int 8MHz crystal (16MHz not working with less than 5V PSU)
board_fuses.efuse = 0xFE ;BOD at 1.8V, perfect for low power
upload_port = usb
upload_flags =
-C
${platformio.packages_dir}/tool-avrdude/avrdude.conf
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
atmelice_isp
-e
src_filter= -<*> +<face>
build_flags = -DFACE_BUILD -Icommon
test_filter = test_common test_face
paulstoffregen/OneWire@^2.3.8
Any Idea what could be wrong? There is not a lot of posts on the t814 on PIO, and I didnt see a lot of stuff with atmelmegaavr either.
A syntax error there usually means a version mismatch between the avrdude binary (avrdude.exe) and the configuration file (avrdude.conf); for example, avrdude 6.x cannot read the config file meant for avrdude 7.x.
The problem is that, even though this is the officially recommended way using upload_flags, this is still fragile. It assumes that the avrdude folder that PlatformIO uses for this project is tool-avrdude. But it could also be a different version, e.g. tool-avrdude@<some version>.
Sadly PlatformIO does not have a $[platformio.packages_dir.tool-avrdude} sort of interpolation that always returns the actual used folder for a package.
So, you should look in your C:\Users\<user>\.platformio\packages\ folder and see what sort of tool-avrdude* folders exist, and adapt this path as needed.
Thank you, I can upload now!
Also, I didn’t know but ATtiny814 uses UPDI and not ISP (though the 2 protocols use the same 6-pin header, just a different pinout) so it was important to change both these lines:
upload_flags =
-C
${platformio.packages_dir}/tool-avrdude@1.70100.0/avrdude.conf ; HERE
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
atmelice_updi ; HERE
-e
