I am trying to start a basic project for a ESP32-PICO using PlatformIO
My platformio.ini looks like
[platformio]
src_dir = ./
[env:testbench]
framework = espidf
board = pico32
My sdkconfig.defaults looks like
CONFIG_AUTOSTART_ARDUINO=y
# CONFIG_WS2812_LED_ENABLE is not set
CONFIG_FREERTOS_HZ=1000
CONFIG_MBEDTLS_PSK_MODES=y
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=y
The source code looks like
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_log.h"
void app_main(void)
while (true)
printf("Hello World\n");
vTaskDelay(1000 / portTICK_PERIOD_MS);
The root of the project is indeed a git repo, git status returns the correct status, it does have a commit, and git rev-parse HEAD returns a hash. The git installation was updated to the latest as of today.
When I click build, the full error message is
Executing task: C:\Users\frank\.platformio\penv\Scripts\platformio.exe run --environment testbench
Processing testbench (platform: espressif32; framework: espidf; board: pico32)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/pico32.html
PLATFORM: Espressif 32 (6.8.1) > ESP32 Pico Kit
- framework-espidf @ 3.50300.0 (5.3.0)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
- tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
- toolchain-esp32ulp @ 1.23800.240113 (2.38.0)
- toolchain-xtensa-esp-elf @ 13.2.0+20240530
-- git rev-parse returned 'fatal: not a git repository (or any of the parent directories): .git'
-- Building ESP-IDF components for target esp32
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.46.0.windows.1")
-- Configuring incomplete, errors occurred!
See also "D:/GithubRepos/Shrew-TestBench/.pio/build/testbench/CMakeFiles/CMakeOutput.log".
CMake Error at C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/component.cmake:225 (message):
CMake Warning (dev) at .pio/build/testbench/build_properties.temp.cmake:8:
Syntax Warning in cmake code at column 106
Argument not separated from preceding token by whitespace.
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/scripts/component_get_requirements.cmake:3 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Error at
C:/Users/frank/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/ExternalProject.cmake:1029
(define_property):
define_property command is not scriptable
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/kconfig.cmake:1 (include)
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/idf.cmake:43 (include)
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/project.cmake:29 (include)
CMakeLists.txt:2 (include)
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/scripts/component_get_requirements.cmake:107 (include)
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/scripts/component_get_requirements.cmake:127 (__component_get_requirements)
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/build.cmake:586 (__component_get_requirements)
C:/Users/frank/.platformio/packages/framework-espidf/tools/cmake/project.cmake:710 (idf_build_process)
CMakeLists.txt:3 (project)
========================================= [FAILED] Took 2.45 seconds =========================================
* The terminal process "C:\Users\frank\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'testbench'" terminated with exit code: 1.
* Executing task: C:\Users\frank\.platformio\penv\Scripts\platformio.exe run --environment testbench
- tool-idf @ 1.0.1
CMake Error at
(define_property):
========================================= [FAILED] Took 2.38 seconds =========================================
I have completely wiped out the .platformio directory from my user directory already, all the platforms and packages have been reinstalled, and the issue was not resolved.
Reinstalling git did not resolve the issue.
I have read all of these search results and none of them had a solution that worked
Please help! Thanks!
EDIT: Interesting… I installed the ESP-IDF extension for VSCode and then tried to build a template project. I get the same error about git
