I get the following error:
No source file named e:\Users\class\Desktop\atmega328p docs\Visual Studio Code Project\atmega328p_lib\src\main.c. (from break-insert "e:\\Users\\class\\Desktop\\atmega328p docs\\Visual Studio Code Project\\atmega328p_lib\\src\\main.c:53")
I added build_flags = -g to .ini file. I also check to see that the source file is located at the above directory (I can find main.c if I go to that location)
the log from platformio debug console:
Reading symbols from e:\Users\class\Desktop\atmega328p docs\Visual Studio Code Project\atmega328p_lib\.pio\build\uno\firmware.elf...
done.
PlatformIO: debug_tool = avr-stub
0x00001416 in main ()
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
I am using both the red dot breakpoints and manual calls to breakpoint(). Debug mode does not run to any of the breakpoints I set.
Restart debugging and when the first breakpoint is hit (by a hopefully breakpoint();
call or by pressing the pause button), execute
break main.c:53
in the “Debug Console” console (aka, GDB). What does it output?
And after that, maybe a info breakpoints
would be good.
heres the info you requested:
done.
0x000014cc in main ()
Program received signal
SIGINT, Interrupt.
break main.c:53
No source file named main.c.
Make breakpoint pending on future shared library load? (y or [n]) [answered N; input not from terminal]
{"token":28,"outOfBandRecord":[],"resultRecords":{"resultClass":"done","results":[]}}
info breakpoints
No breakpoints or watchpoints.
{"token":30,"outOfBandRecord":[],"resultRecords":{"resultClass":"done","results":[]}}
Heres a pic of the IDE:
