Having created a project for my arduino uno and tried to build the simple blink_led program. But the compiler does not seem to be able to find the inttypes.h and stdlib.h standard headerfiles even though i have VS2015 installed. Is there any way point paltformio to the header files as i know where they are located…
Could you provide a simple project to reproduce this issue?
I have just used the blink example only including arduino.h
https://hastebin.com/ikutukobod.cpp
Something is wrong with platform packages. Try to remove C:\Users\xxxx.platformio folder
oh it might be because i have set the HOME environment variable to my dropbox such that platformio places the .platformio folder there instead of the user folder
It should not be a problem. What do you see with
pio platform list
Not OP, but I’m having this exact issue.
when I type pio platform list
, I get:
atmelavr ~ Atmel AVR
Atmel AVR 8- and 32-bit MCUs deliver a unique combination of performance, power efficiency and
design flexibility. Optimized to speed time to market-and easily adapt to new ones-they are b
ased on the industrys most code-efficient architecture for C and assembly programming.
Home: http://platformio.org/platforms/atmelavr
Frameworks: arduino, simba
Packages: toolchain-atmelavr, framework-arduinoavr, framework-simba, tool-avrdude, tool-micron
ucleus
Version: 1.10.0
