Here is the log info:
Executing task: C:\Users\20597.platformio\penv\Scripts\platformio.exe run <
Processing emulator (platform: espressif32; board: esp32dev; framework: espidf)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing ttgo-tdisplay-emulator @ *
Error: Could not find the package with ‘ttgo-tdisplay-emulator @ *’ requirements for your system ‘windows_amd64’
The terminal process “C:\Users\20597.platformio\penv\Scripts\platformio.exe ‘run’” terminated with exit code: 1.
And the related code in platform.ini:
[env:emulator]
platform_packages = ttgo-tdisplay-emulator
upload_protocol = custom
upload_command = $PROJECT_PACKAGES_DIR/ttgo-tdisplay-emulator/emulate $SOURCE $BUILD_DIR $PROJECT_PACKAGES_DIR
Why it can’t install the specified platform_package? Should I download some package in somewhere before I build the project?
