Unable to install Platformio using VSCode or Atom
Either installation hangs with the “Welcome to PlatformIO” page which includes a “Reconnect” spinning circle. A “Core” version spinning circle and a spinning circle above the word “Loading…”. “Home” on the page shows version 0.2.5. I cannot go father.
I’m on an iMac with OS X 10.11.6. Any help would be appreciated.
I’ve been using atom with PlatformIO on this machine for while and it just stopped working a couple of days ago after an update.
EDIT: Works with 10.12.6. DOES NOT WORK WITH 10.11.6
Please provide an output from a system Terminal
echo $PATH
echo $PYTHONPATH
python --version
pip --version
pip list
PATH = /Users/carl/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin
PYTHONPATH =
Python 2.7.10
pip 9.0.1 from /Library/Python/2.7/site-packages/pip-9.0.1-py2.7.egg (python 2.7)
pip list:
altgraph (0.10.2)
bdist-mpkg (0.5.0)
bonjour-py (0.3)
macholib (1.5.1)
matplotlib (1.3.1)
modulegraph (0.10.4)
numpy (1.8.0rc1)
pip (9.0.1)
py2app (0.7.3)
pyobjc-core (2.5.1)
pyobjc-framework-Accounts (2.5.1)
pyobjc-framework-AddressBook (2.5.1)
pyobjc-framework-AppleScriptKit (2.5.1)
pyobjc-framework-AppleScriptObjC (2.5.1)
pyobjc-framework-Automator (2.5.1)
pyobjc-framework-CFNetwork (2.5.1)
pyobjc-framework-Cocoa (2.5.1)
pyobjc-framework-Collaboration (2.5.1)
pyobjc-framework-CoreData (2.5.1)
pyobjc-framework-CoreLocation (2.5.1)
pyobjc-framework-CoreText (2.5.1)
pyobjc-framework-DictionaryServices (2.5.1)
pyobjc-framework-EventKit (2.5.1)
pyobjc-framework-ExceptionHandling (2.5.1)
pyobjc-framework-FSEvents (2.5.1)
pyobjc-framework-InputMethodKit (2.5.1)
pyobjc-framework-InstallerPlugins (2.5.1)
pyobjc-framework-InstantMessage (2.5.1)
pyobjc-framework-LatentSemanticMapping (2.5.1)
pyobjc-framework-LaunchServices (2.5.1)
pyobjc-framework-Message (2.5.1)
pyobjc-framework-OpenDirectory (2.5.1)
pyobjc-framework-PreferencePanes (2.5.1)
pyobjc-framework-PubSub (2.5.1)
pyobjc-framework-QTKit (2.5.1)
pyobjc-framework-Quartz (2.5.1)
pyobjc-framework-ScreenSaver (2.5.1)
pyobjc-framework-ScriptingBridge (2.5.1)
pyobjc-framework-SearchKit (2.5.1)
pyobjc-framework-ServiceManagement (2.5.1)
pyobjc-framework-Social (2.5.1)
pyobjc-framework-SyncServices (2.5.1)
pyobjc-framework-SystemConfiguration (2.5.1)
pyobjc-framework-WebKit (2.5.1)
pyOpenSSL (0.13.1)
pyparsing (2.0.1)
PyPrind (2.11.1)
pyserial (3.4)
python-dateutil (1.5)
pytz (2013.7)
scipy (0.13.0b1)
setuptools (1.1.6)
six (1.4.1)
xattr (0.6.4)
zope.interface (4.1.1)
Please open system terminal (not terminal in PIO IDE) and run:
~/.platformio/penv/bin/platformio home
It should open PIO Home in new browser window. Does it work here?
In the terminal:
PlatformIO Plus (https://pioplus.com) v0.10.8
I
–\ PlatformIO Home
/ _-
|[]| [] | http://127.0.0.1:8008
|____|______________________
And in the new browser window the same same result as before. Still trying to reconnect.
Could try to open PIO IDE Terminal and type
pio upgrade
pio update
Now, please restart IDE. Does it work now?
Sorry, no it doesn’t. Did a clean out and a complete reinstall with the same result. I’ve moved off the iMac with the problem to a macbook pro which works so it takes me a moment to switch back.
