Hi.
I tried to include stl::functional to a project and it do not compile with Arduino DUE programing port.
I tried with the arduino IDE and it compile. On platformIO I got a really long list of error…
I was tried with an empty sketch with arduio.h include, setup and loop definition…
Here the error given:
Thanks
platformio core 5.0.1
n file included from c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\char_traits.h:39:0,
from c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\string:40,
from c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\stdexcept:39,
from c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\array:39,
from c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\tuple:39,
from c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\functional:54,
from src\main.cpp:3:
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:243:56: error: macro "min" passed 3 arguments, but takes just 2
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:265:56: error: macro "max" passed 3 arguments, but takes just 2
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
In file included from C:\Users\o_for\.platformio\packages\framework-arduino-sam\system\libsam/chip.h:66:0,
from C:\Users\o_for\.platformio\packages\framework-arduino-sam\cores\arduino/Arduino.h:42,
from src\main.cpp:1:
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:195:5: error: expected unqualified-id before 'const'
min(const _Tp& __a, const _Tp& __b)
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:195:5: error: expected ')' before 'const'
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:195:5: error: expected initializer before 'const'
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:219:5: error: expected unqualified-id before 'const'
max(const _Tp& __a, const _Tp& __b)
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:219:5: error: expected ')' before 'const'
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:219:5: error: expected initializer before 'const'
In file included from c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\char_traits.h:39:0,
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:246:7: error: expected primary-expression before 'if'
if (__comp(__b, __a))
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:246:7: error: expected '}' before 'if'
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:246:7: error: expected ';' before 'if'
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:248:7: error: expected unqualified-id before 'return'
return __a;
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:268:7: error: expected primary-expression before 'if'
if (__comp(__a, __b))
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:268:7: error: expected '}' before 'if'
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:268:7: error: expected ';' before 'if'
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:270:7: error: expected unqualified-id before 'return'
return __a;
c:\users\o_for\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:271:5: error: expected declaration before '}' token
*** [.pio\build\due\src\main.cpp.o] Error 1
