It seems for ESP32 project C++ STL library is by default linked per this topic. However, I can not include STL libraries. For example if I try #include <array>
I get;
/Users/username/.platformio/penv/lib/python3.9/site-packages/urllib3/__init__.py:34: NotOpenSSLWarning: urllib3 v2.0 only supports OpenSSL 1.1.1+, currently the 'ssl' module is compiled with 'LibreSSL 2.8.3'. See: https://github.com/urllib3/urllib3/issues/3020
warnings.warn(
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
warnings.warn(
PLATFORM: Espressif 32 (6.3.2) > Espressif ESP32 Dev Module
- framework-espidf @ 3.50002.230601 (5.0.2)
- tool-cmake @ 3.16.4
- tool-mkfatfs @ 2.0.1
- tool-ninja @ 1.9.0
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-xtensa-esp32 @ 11.2.0+2022r1
Found 1 compatible libraries
Compiling .pio/build/esp32dev/src/main.o
Generating LD script .pio/build/esp32dev/memory.ld
src/main.c:2:10: fatal error: array: No such file or directory
2 | #include <array>
compilation terminated.
Compiling .pio/build/esp32dev/app_trace/app_trace.o
Compiling .pio/build/esp32dev/app_trace/app_trace_util.o
Compiling .pio/build/esp32dev/app_trace/host_file_io.o
Compiling .pio/build/esp32dev/app_trace/gcov/gcov_rtio.o
Compiling .pio/build/esp32dev/app_trace/port/port_uart.o
Compiling .pio/build/esp32dev/app_update/esp_ota_ops.o
Compiling .pio/build/esp32dev/app_update/esp_ota_app_desc.o
*** [.pio/build/esp32dev/src/main.o] Error 1
Compiling .pio/build/esp32dev/bootloader_support/src/bootloader_common.o
=========================================================================================== [FAILED] Took 1.58 seconds ===========================================================================================
My plotformio.ini
is like below.
framework = espidf
upload_port = /dev//dev/cu.SLAB_USBtoUART
It is pretty much the default project as is. What should I do or check to use STL?
