I am running the current version of VSC with PlatformIO. I am trying to flash a file to an ESP8285 (ESP-m3 to be precise). I can erase flash and flash to the chip in a terminal window in a Linux terminal window on Mint 19.3. I am using esptool.py v 3.0 to do that flash and it works just fine. When I try to flash a file to it in VSC/PlatformIO, (which I guess is using v2.8?) it fails to connect and times out. The messages are seemingly the same as far as content. I am confused.
This is my Platformio.ini fileâŚ
Since I can only put one picture per post in at this point⌠gotta love anti-spam measuresâŚ
The terminal window on Linux Mint 19.3
Seems like v2.8 of esptool canât reset the ESP into bootloader mode. How is the ESP connected to the usb-uart adapter, especially regarding the DTR and RTS pins?
Seems to me like youâre just missing the correct reset method declaration. (Espressif 8266 â PlatformIO latest documentation)
Edit: To clarify that thing with upload methods, this is a property that comes from the chosen board = x
line (the default value at least, still overrideable as seen in link above). You have board = esp8285
which maps to PlatformIOâs board JSON file
due to this definition, PIO will call esptool.py
with the reset method flag âckâ (method again explained in link). If the reset method is the problem, you may also try to just set another board = x
which directly has the reset method. You can browse all available board json filse (and thus possible board
values, just without the .json
extension` from the link above.
In any case, the goal is to that you should just match all other settings as well in the platformio.ini
, regarding flash size (ldscript
and maximum_size
) , flash mode (DIO/QIO/DOUT/QOUT), flash frequency (20, 26 , 40 or 80MHz) etc. as the default settings there might be wrong for you. The docs link above again tell you how you can change each specific setting, together with the board documentation.
I believe you are probably correct. I have noticed that there are settings that apply in VSC/PlatformIO that donât seem to exist in other applications. I was not aware of that flag. Will try that once I get back home and can take shot at it. I made a programmer board that has the programmer adapter on it and has a row of pogo pins. Press it on the board, tell it to flash. Will keep you posted. Thank You
Thank you Max! It was exactly what you said. I have the 8285 board (ESP-M3) mounted onto a receiver board that a friend designed that uses the NodeMCU reset transistor setup so it does use the same reset as the NodeMCU dev board. I added the reset method line to my .ini file and gave it the ânodemcuâ flag. It flashed up perfectly. PlatformIO just didnât know what to do to put the board in bootloader mode.
That resolves a LOT of issues I have had but didnât know why.
Thank you. I had the same problem, and I solved this problem after reading your discussion. But of course, this still took me some time, so I release my solution intuitively here:
