For some reason my production boards don’t boot if not flashed in QOUT mode.
I have tried just about everything but no matter what flashing in Platformio uses DIO mode,
This is the platformio file
[env:esp32dev2]
upload_speed=921600
board_build.flash_mode = qout
board_build.f_flash = 80000000L
build_flags = -DCORE_DEBUG_LEVEL=5
Any ideas?
Yes, there is an override. See
How can i get around this ?
Well comments in Fix flash mode for `opi` by Jason2866 · Pull Request #904 · platformio/platform-espressif32 · GitHub claim the override is correct though…
If you want to test what happens without it, just add a
extra_script = disable_override.py
to your environment with the file’s content being
Import("env")
def get_board_flash_mode(env):
return env.subst("$BOARD_FLASH_MODE")
env.Replace(
__get_board_flash_mode=get_board_flash_mode
Thanks.
So strange that it can’t boot on the newest versions but on @1.0.6 it works perfectly.
this is the error
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0xff001cff,len:267327
1150 mmu set 00010000, pos 00010000
1150 mmu set 00020000, pos 00020000
1150 mmu set 00030000, pos 00030000
1150 mmu set 00040000, pos 00040000
ho 0 tail 11 room 5
