Hello.
I work on a Linux mint system and are a member of the dialout and plugdev group (I read somewhere that that is necessary) PlatformIO is unable to detect the boards, i tried it with the boot button pressed and unpressed and with 3 different cables, googled the problem but what i found was a little bit over my head. i’m at a loss what to do next, can someone please point me in the right direction?
I recently bought a lilygo T-QT ant t display s3 , and when i wanted to up lode the demo it compiled successful, but it wouldn’t up lode to both boards. I got the following messages:
- Executing task: platformio run --target upload
Processing ESP32-S3-DevKitC-1 (platform: espressif32; board: esp32-s3-devkitc-1; framework: arduino)
Verbose mode can be enabled via
-v, --verboseoption
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (5.2.0) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 2.0.3+sha.142fceb
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- tool-mkfatfs @ 2.0.1
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch3
Converting lcd.ino
Found 35 compatible libraries
Scanning dependencies…
|-- SPI @ 2.0.0
Compiling .pio/build/ESP32-S3-DevKitC-1/src/lcd.ino.cpp.o
Retrieving maximum program size .pio/build/ESP32-S3-DevKitC-1/firmware.elf
Checking size .pio/build/ESP32-S3-DevKitC-1/firmware.elf
RAM: [ ] 4.0% (used 13232 bytes from 327680 bytes)
Flash: [== ] 20.3% (used 266693 bytes from 1310720 bytes)
Configuring upload protocol…
AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port…
Error: Please specifyupload_portfor environment or use global--upload-portoption.
For some development platforms it can be a USB flash drive (i.e. /media//)
*** [upload] Explicit exit, status 1
============================================================================= [FAILED] Took 5.97 seconds =============================================================================
- The terminal process “platformio ‘run’, ‘–target’, ‘upload’” terminated with exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
kint regards bert
