Unable to debug ATMEGE 2560 project
now deinstalled and after adding “debug_init();” to setup I received folloeing error:
Linking .pio\build\megaatmega2560\firmware.elf
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_25'
avr8-stub.c.o (symbol from plugin):(.text+0x0): first defined here
WInterrupts.c.o (symbol from plugin): In function `attachInterrupt':
(.text+0x0): multiple definition of `__vector_1'
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\megaatmega2560\firmware.elf] Error 1
=============================================== [FAILED] Took 6.45 seconds ===============================================
 *  The terminal process "C:\Users\User\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
here the setup function, maybe you can tell me which interrupt is the problem, is it not allowed to use Serial.Print during debugging? I thought using another serial port is possible, for instance Serial3.
void setup()
  // initialize GDB stub
  debug_init();
  cli();
  // Pin change IRQ control register
  // X X X X X PCIE2 PCIE1 PCIE0
  PCICR |= 0b00000100;
  // Pin Change Mask Register 0
  // PCINT7 PCINT6 PCINT5 PCINT4 PCINT3 PCINT2 PCINT1 PCINT0
  PCMSK0 |= 0b00000000;
  // PCINT15 PCINT14 PCINT13 PCINT12 PCINT11 PCINT10 PCINT9 PCINT8
  PCMSK1 |= 0b00000000;
  // PCINT23 PCINT22 PCINT21 PCINT20 PCINT19 PCINT18 PCINT17 PCINT16
  PCMSK2 |= 0b00001111;
  DDRK = 0x00;   // Port K as INPUT (1 = OUTPUT)
  PORTK = 0xFF;  // pullup enable
  //set timer0 interrupt at 2kHz
  TCCR0A = 0;// set entire TCCR2A register to 0
  TCNT0  = 0;//initialize counter value to 0
  // set compare match register for 2khz increments
  OCR0A = 0x10;// = (16*10^6) / (200*64) - 1 8Bit register !!!
  // turn on CTC mode
  TCCR0A |= (1 << WGM01);
  TIMSK0 |= (1 << OCIE0A);
  sei();//allow interrupts
  Serial3.begin(38400);
  rxBufLen = 0u;
  if(CAN0.begin(MCP_ANY, CAN_125KBPS, MCP_8MHZ) == CAN_OK)
    Serial3.println("MCP2515 Initialized Successfully!");
  else
    Serial3.println("Error Initializing MCP2515...");
  CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
  digitalWrite(LED1,LOW);
  digitalWrite(LED2,LOW);
  digitalWrite(RELAIS1,HIGH);
  digitalWrite(RELAIS2,HIGH);
  digitalWrite(RELAIS3,HIGH);
  pinMode(DI_IRQ_MCP_CAN, INPUT);  // Configuring pin for IRQ input Pin2
  pinMode(DI_CheckFlimSwitch, INPUT); // Configuring pin
  pinMode(DI_Start, INPUT); // Configuring pin
  pinMode(DI_Stop, INPUT); // Configuring pin
  pinMode(DI_InPos1, INPUT); // Configuring pin
  pinMode(DI_BoltOK_IN, INPUT); // Configuring pin
  pinMode(DI_GearCount1, INPUT); // Configuring pin
  pinMode(DI_GearCount2, INPUT); // Configuring pin
  attachInterrupt(digitalPinToInterrupt(DI_IRQ_MCP_CAN), ext_IRQ0, FALLING);
  attachInterrupt(digitalPinToInterrupt(DI_InPos1), ext_IRQ1, RISING);
  attachInterrupt(digitalPinToInterrupt(DI_GearCount1), ext_IRQ4, RISING);
  attachInterrupt(digitalPinToInterrupt(DI_ReferenzOK), ext_IRQ5, RISING);
  pciSetup(7);
  pciSetup(8);
  pciSetup(9);
  pciSetup(A0);
  Serial3.println("MCP2515 Library Receive Example...");
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
   Serial3.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  display.display();
  delay(2000); // Pause for 2 seconds
  // Clear the buffer
  display.clearDisplay();
  myservo0.attach(9);  // attaches the servo on pin 9/10 to the servo object
  myservo0.write(0);   //0..180
  myservo1.attach(10); // attaches the servo on pin 9/10 to the servo object
  myservo1.write(0);   //0..180
  canbusRecv = 0;
  ptxBuf=txBuf;
  FYNcontr.Bitcountbyte = 8u;
  Serial3.println("Timer ready...");
  wdt_enable(WDTO_1S);
  Serial3.println("Watchdog ready...");
