I have a simple example sketch that uses the built in Adafruit_TinyUSB library which compiles fine with Arduino IDE but I cant get it to work with PlatformIO.
I am using a Pi Pico. I get conflicting declaration compile errors when I use build_flags = -DUSE_TINYUSB
In file included from .pio\libdeps\pico\Adafruit TinyUSB Library\src\arduino\Adafruit_USBD_CDC.cpp:29:
C:\Users\ali.platformio\packages\framework-arduino-mbed@3.5.4\cores\arduino/Arduino.h:105:17: error: conflicting declaration ‘Adafruit_USBD_CDC UART_USB’
105 | #define Serial UART_USB
.pio\libdeps\pico\Adafruit TinyUSB Library\src\arduino\Adafruit_USBD_CDC.h:97:26: note: in expansion of macro ‘Serial’
97 | extern Adafruit_USBD_CDC Serial;
In file included from C:\Users\ali.platformio\packages\framework-arduino-mbed@3.5.4\cores\arduino/Arduino.h:102,
C:\Users\ali.platformio\packages\framework-arduino-mbed@3.5.4\cores\arduino/Serial.h:88:22: note: previous declaration as ‘arduino::UART UART_USB’
88 | extern arduino::UART UART_USB;
If I remove the define USE_TINYUSB build flag, it compiles but it does not work because it uses Pico SDK USB stack.
I have tried also adding dependency to the GitHub - adafruit/Adafruit_TinyUSB_Arduino: Arduino library for TinyUSB library but no change as its already built in.
My platformio.ini has:
[env:pico]
platform = raspberrypi
board = pico
lib_archive = no
upload_protocol = picotool
upload_port=D:
Any ideas on how I can get overcome this compile error in platformIO?
