Hi, I created a blank uno project, just the startup and loop in there and it fails compilation
> Executing task in folder heat controller: C:\Users\spenc\.platformio\penv\Scripts\pio.exe run <
Processing uno (platform: atmelavr; board: uno; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.0.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
Compiling .pio\build\uno\src\main.cpp.o
Archiving .pio\build\uno\libFrameworkArduinoVariant.a
Compiling .pio\build\uno\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o
Compiling .pio\build\uno\FrameworkArduino\IPAddress.cpp.o
avr-gcc-ar: Cannot find plugin 'liblto_plugin-0.dll'
Compiling .pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o
avr-g++: error: device-specs/specs-atmega328p: No such file or directory
Compiling .pio\build\uno\FrameworkArduino\Print.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Stream.cpp.o
*** [.pio\build\uno\src\main.cpp.o] Error 1
*** [.pio\build\uno\libFrameworkArduinoVariant.a] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\CDC.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\Stream.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\Print.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\IPAddress.cpp.o] Error 1
================================================================================================== [FAILED] Took 1.96 seconds ==================================================================================================
The terminal process "C:\Users\spenc\.platformio\penv\Scripts\pio.exe 'run'" terminated with exit code: 1.
