I just installed the PlatformIO extension in VS Code and I cannot for the life of me get it to compile anything. I have tried both empty projects and example code, as well as various boards. I have also tried uninstalled/reinstalling VS Code and the PlatformIO extension numerous times.
I am using Windows 11 and VS Code version: 1.73.1
The PlatformIO extension lists Core: 6.1.5 and Home: 3.4.3
Below is the terminal output when attempting to compile an empty program with Arduino Uno selected as the board:
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (4.0.0) > Arduino Uno
- framework-arduino-avr @ 5.1.0
Found 5 compatible libraries
Compiling .pio\build\uno\src\main.cpp.o
Archiving .pio\build\uno\libFrameworkArduinoVariant.a
Compiling .pio\build\uno\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o
Compiling .pio\build\uno\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Print.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Stream.cpp.o
*** [.pio\build\uno\src\main.cpp.o] Error 1
*** [.pio\build\uno\libFrameworkArduinoVariant.a] Error 1
*** [.pio\build\uno\FrameworkArduino\CDC.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\IPAddress.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\Print.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\Stream.cpp.o] Error 1
And below is the output when using the verbose build option:
avr-g++ -o .pio\build\uno\src\main.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -Iinclude -Isrc -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard src\main.cpp
avr-gcc-ar rc .pio\build\uno\libFrameworkArduinoVariant.a
avr-g++ -o .pio\build\uno\FrameworkArduino\CDC.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\CDC.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\HardwareSerial.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\HardwareSerial0.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\HardwareSerial1.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\HardwareSerial2.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packag*** [.pio\build\uno\src\main.cpp.o] Error 1
es*** [.pio\build\uno\libFrameworkArduinoVariant.a] Error 1
\fr*** [.pio\build\uno\FrameworkArduino\CDC.cpp.o] Error 1
ame*** [.pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o] Error 1
wor*** [.pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o] Error 1
k-ar*** [.pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o] Error 1
dui*** [.pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o] Error 1
no-*** [.pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o] Error 1
avr*** [.pio\build\uno\FrameworkArduino\IPAddress.cpp.o] Error 1
\co*** [.pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o] Error 1
res\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\va*** [.pio\build\uno\FrameworkArduino\Print.cpp.o] Error 1
riants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\HardwareSerial3.cpp*** [.pio\build\uno\FrameworkArduino\Stream.cpp.o] Error 1
avr-g++ -o .pio\build\uno\FrameworkArduino\IPAddress.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\IPAddress.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\PluggableUSB.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\Print.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\Print.cpp
avr-g++ -o .pio\build\uno\FrameworkArduino\Stream.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DPLATFORMIO=60105 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\ethan\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\ethan\.platformio\packages\framework-arduino-avr\cores\arduino\Stream.cpp
