I have been trying to start a project using Simba on an Arduino Uno board. I have the initial install working, but the version of Simba that is used by default when it is specified as the framework is extremely old. I have been trying to follow the advice in this post: How to specify desired version of an installed framework?
I also found found this in the docs: Redirecting...
However, once I try to specify a newer version of Simba, nothing happens. pio update does nothing to change the package, and pio run will recompile everything but no changes to the framework package occur. This version of simba doesn’t even have the ability to activate pull up/down resistors. This is my current platformio.ini entry:
[env:uno]
platform_packages =
framework-simba@>14.0.0
board = uno
framework = simba
Any help on figuring out how to install the newer version of the framework would be appreciated for this platformio newbie.
