I am using Platformio with ESP32 and everything was working for long time.
Now when I upload the firmware to the target, the following command is executed:
Executing task in folder Focuser: C:.platformio\penv\Scripts\platformio.exe run --target upload --environment esp32doit-devkit-v1 --upload-port COM8
The problem is that the COM8 does not exists (the correct com is COM14).
In the platformio.ini I have set:
[env:esp32doit-devkit-v1]
platform = espressif32@3.0.0
board = esp32doit-devkit-v1
board_build.partitions = default.csv
; Serial Monitor options
monitor_port = COM14
; Serial Upload options
upload_port = COM14
upload_speed = 1152000
Using the terminal I am able to use connect to COM14, as expected.
I am going crazy I have not idea where the COM8 is taken.
Thank you
