Only made a minor configuration change and unable to build.
Made sure to update PIO to most recent, compared master rep from Big Skr with local rep and no obvious errors.
Error begins with the following from below:
NameError: name ‘env’ is not defined:
File “C:\Users\Josh.platformio\penv\lib\site-packages\platformio\builder\main.py”, line 182:
env.SConscript(env.GetExtraScripts(“post”), exports=“env”)
Log from attempted build:
CONFIGURATION: Redirecting...
PLATFORM: ST STM32 (6.1.1) > STM32F103RC (48k RAM. 256k Flash)
HARDWARE: STM32F103RCT6 72MHz, 48KB RAM, 256KB Flash
DEBUG: Current (blackmagic) External (blackmagic, jlink, stlink)
- framework-arduinoststm32-maple @ 2.10000.200103 (1.0.0)
- tool-stm32duino @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Converting Marlin.ino
Found 31 compatible libraries
Scanning dependencies…
|-- SoftwareSerialM @ 1.0.0
|-- TMCStepper @ 0.7.3
|-- U8glib-HAL @ 0.4.5
|-- STM32ADC @ 1.0
|-- EEPROM
|-- Wire @ 1.0
|-- USBComposite for STM32F1 @ 0.91
|-- Servo(STM32F1) @ 1.1.2
File “C:\Users\Josh.platformio\packages\tool-scons\scons-local-4.5.2\SCons\Script\SConscript.py”, line 598:
File “C:\Users\Josh.platformio\packages\tool-scons\scons-local-4.5.2\SCons\Script\SConscript.py”, line 285:
exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals)
File “C:\Users\Josh\Documents\GitHub\BIGTREETECH-SKR-mini-E3\firmware\V1.2\Marlin-2.0.7.2-SKR-mini-E3-V1.2\buildroot\share\PlatformIO\scripts\STM32F103RC_SKR_MINI.py”, line 7:
for define in env[‘CPPDEFINES’]:
=========================================================================== [FAILED] Took 17.86 seconds ===========================================================================
Environment Status Duration
STM32F103RC_btt FAILED 00:00:17.857
====================================================================== 1 failed, 0 succeeded in 00:00:17.857 ======================================================================
- The terminal process “C:\Users\Josh.platformio\penv\Scripts\platformio.exe ‘run’, ‘–environment’, ‘STM32F103RC_btt’” terminated with exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
Screenshot and snippet
import os
Import(“env”)
STM32_FLASH_SIZE = 256
if define[0] == “VECT_TAB_ADDR”:
env[‘CPPDEFINES’].remove(define)
if define[0] == “STM32_FLASH_SIZE”:
STM32_FLASH_SIZE = define[1]
Relocate firmware from 0x08000000 to 0x08007000
env[‘CPPDEFINES’].append((“VECT_TAB_ADDR”, “0x08007000”))
custom_ld_script = os.path.abspath(“buildroot/share/PlatformIO/ldscripts/STM32F103RC_SKR_MINI_” + str(STM32_FLASH_SIZE) + “K.ld”)
for i, flag in enumerate(env[“LINKFLAGS”]):
if “-Wl,-T” in flag:
env[“LINKFLAGS”][i] = “-Wl,-T” + custom_ld_script
elif flag == “-T”:
env[“LINKFLAGS”][i + 1] = custom_ld_script
I have a identical problem with SKR MINI E3 2.0 and Marlin 2.0.7.2. I need rebuild this version of Marlin. I’m not interested newer or older Marlin version.
My Visual Studio Code is actual
How can help me ?
Warning! Ignore unknown configuration option `monitor_flags` in section [env]
Warning! `src_filter` configuration option in section [env:DUE] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:SAMD51_grandcentral_m4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:STM32F4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:STM32F7] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:malyan_M300] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:esp32] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy31] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy35] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy36] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy41] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_build_flags` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_flags` instead
Warning! `src_filter` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:include_tree] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Resolving STM32F103RC_btt_512K dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Warning! Ignore unknown configuration option `monitor_flags` in section [env]
Processing STM32F103RC_btt_512K (platform: ststm32@~6.1; board: genericSTM32F103RC; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103RC.html
HARDWARE: STM32F103RCT6 72MHz, 48KB RAM, 512KB Flash
Found 32 compatible libraries
|-- TMCStepper @ 0.7.1
|-- Adafruit NeoPixel @ 1.2.4+sha.b72627a
|-- U8glib-HAL @ 0.4.3
|-- STM32ADC @ 1.0
|-- EEPROM
|-- Wire @ 1.0
RuntimeError: deque mutated during iteration:
File "C:\Users\zzz\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 182:
env.SConscript(env.GetExtraScripts("post"), exports="env")
File "C:\Users\zzz\.platformio\packages\tool-scons\scons-local-4.5.2\SCons\Script\SConscript.py", line 598:
File "C:\Users\zzz\.platformio\packages\tool-scons\scons-local-4.5.2\SCons\Script\SConscript.py", line 285:
File "C:\BIGTREETECH-SKR-mini-E3\firmware\V2.0\Marlin-2.0.7.2-SKR-mini-E3-V2.0\buildroot\share\PlatformIO\scripts\STM32F103RC_SKR_MINI.py", line 6:
for define in env['CPPDEFINES']:
========================= [FAILED] Took 43.28 seconds =========================
STM32F103RC_btt_512K FAILED 00:00:43.276
==================== 1 failed, 0 succeeded in 00:00:43.276 ====================
We already discussed that in Trying to compile Marlin 2.1.2 for Ender 3 SKR Mini v2.0 board - #9 by maxgerhardt
Otherwise you’d need to install a much lower PlatformIO core version, or Python version.
Thank you I updated this in STM32F103RC_SKR_MINI.py and commented out the older function.
Then was able to build marlin successfully
