I’m trying to build and upload data folder files but I got error while building image.
error is written below which I see in my serial monitor.
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (6.0.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 @ 3.20006.221224 (2.0.6)
- tool-esptoolpy @ 1.40400.0 (4.4.0)
Found 40 compatible libraries
Scanning dependencies…
|-- WebSockets @ 2.3.7
|-- ArduinoJson @ 6.21.0
|-- ESP Async WebServer @ 1.2.3+sha.f71e3d4
|-- ESPAsyncWebServer-esphome @ 3.0.0
|-- EEPROM @ 2.0.0
|-- SPIFFS @ 2.0.0
|-- WiFi @ 2.0.0
Building FS image from ‘data’ directory to .pio\build\esp32doit-devkit-v1\spiffs.bin
/favicon.png
/index.html
/logo.svg
/robots.txt
/_app/immutable/assets/_layout.0e6de7f8.css
/_app/immutable/chunks/0.ddfa57f2.mjs
SPIFFS_write error(-10010): unknown
/_app/immutable/entry/app.04751647.mjs
/_app/version.json
error adding file!
Error for adding content from assets!
error adding file!
Error for adding content from chunks!
error adding file!
Error for adding content from entry!
Thanks but this is auto generated files with svelte kit so if i modify file name webpage will not load properly
The other path of allowing longer filenames is harder to achieve, you’d have to fork the Arduino-ESP32 core, possible recompiling the ESP-IDF base with a configuration change and the mkspiffs tool.
Maybe LitteFS has different limitations? Try that filesystem instead
https://docs.platformio.org/en/latest/platforms/espressif32.html#uploading-files-to-file-system
yes LittleFS can create filesystem image but the problem is when i load my webpage normally in esp32 AP mode at time esp32 get panic but when I load page by using slow 3G mode (Chrome DEV tool) at time webpage load fine.
here it’s setup code for webpage,
WiFi.softAP("Motor_Test", "123456789"); // AP mode init
memory_init();
Serial.println("softap");
Serial.println("");
Serial.println(WiFi.softAPIP());
// file system init for sending files to webserver.
LittleFS.begin();
if (!LittleFS.begin())
Serial.println("An error occurred while mounting SPIFFS");
return;
// Serve the index.html files from SPIFFS
webServer.on("/", HTTP_GET, [](AsyncWebServerRequest *request)
{ request->send(LittleFS, "/index.html", "text/html"); });
// webserver loop for sending multiple files from one specific folder
webServer.on("/_app/immutable/assets", HTTP_GET, [](AsyncWebServerRequest *request)
String path = request->url();
if (path.endsWith(".html"))
request->send(LittleFS, path, "text/html");
else if (path.endsWith(".mjs"))
request->send(LittleFS, path, "text/javascript");
else if (path.endsWith(".css"))
request->send(LittleFS, path, "text/css");
else
request->send(404);
webServer.on("/_app/immutable/entry", HTTP_GET, [](AsyncWebServerRequest *request)
else
request->send(404);
webServer.on("/_app/immutable/chunks", HTTP_GET, [](AsyncWebServerRequest *request)
else
request->send(404);
webServer.begin();
I’m afraid that’s a different issue. If you can reproduce it with the standard examples of the library, try contacting the library’s author.
