Unable to build for mbed: fails to include packages deprecated in python 3.12 (pls help)
A few months ago, my project built and uploaded with no problem, however, I am no longer able to build, and I think this may be because I upgraded my Ubuntu system from 22.04 LTS (Jammy Jellyfish), which defaults to python 3.10, to 24.04 LTS (Noble Numbat), which defaults to python 3.12. I suspect this is an issue with the python version because I receive an error message when trying to build for mbed for importing a python library, imp, which is no longer supported with python 3.12, and the file from where the trace begins is in a folder labeled python3.12. It’s worth noting that I have no problem building and uploading with the Arduino environments in this project, so I think Platformio is installed correctly.
To resolve the issue I have tried uninstalling platformio in vscode, and deleting the .platformio folder, and then reinstalling platformio in vscode and rebuilding the .platformio folder when I re-open the project environment. I also downloaded python 3.11, and tried setting that as the interpreter for the file that attempts to import imp, but that just pushed the import error to attempts to import other files that are also not supported with python 3.12.
Please be understanding that this is my first-ever post, and let me know anything I should or shouldn’t include in the future :).
This import error happens when I attempt to build my project:
 *  Executing task: platformio run --environment vitalsMBED
Processing vitalsMBED (platform: nxplpc; board: lpc1768; framework: mbed)
CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc/lpc1768.html
PLATFORM: NXP LPC (10.0.0) > NXP mbed LPC1768
HARDWARE: LPC1768 96MHz, 64KB RAM, 512KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
 - framework-mbed @ 6.61700.231105 (6.17.0)
 - toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
ModuleNotFoundError: No module named 'imp':
  File "/home/torrey/.platformio/penv/lib/python3.12/site-packages/platformio/builder/main.py", line 173:
  File "/home/torrey/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 612:
  File "/home/torrey/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 279:
  File "/home/torrey/.platformio/platforms/nxplpc/builder/main.py", line 116:
  File "/home/torrey/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Util/envs.py", line 251:
  File "/home/torrey/.platformio/penv/lib/python3.12/site-packages/platformio/builder/tools/piobuild.py", line 61:
    env.ProcessProgramDeps()
  File "/home/torrey/.platformio/penv/lib/python3.12/site-packages/platformio/builder/tools/piobuild.py", line 121:
  File "/home/torrey/.platformio/penv/lib/python3.12/site-packages/platformio/builder/tools/piobuild.py", line 347:
    SConscript(env.GetFrameworkScript(name), exports="env")
  File "/home/torrey/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 676:
    return method(*args, **kw)
  File "/home/torrey/.platformio/platforms/nxplpc/builder/frameworks/mbed.py", line 35:
    SConscript(
  File "/home/torrey/.platformio/packages/framework-mbed/platformio/platformio-build.py", line 37:
    from pio_mbed_adapter import PlatformioMbedAdapter
  File "/home/torrey/.platformio/packages/framework-mbed/platformio/pio_mbed_adapter.py", line 52:
    from tools.build_api import prepare_toolchain, UPDATE_WHITELIST
  File "/home/torrey/.platformio/packages/framework-mbed/tools/build_api.py", line 48:
    from .libraries import Library
  File "/home/torrey/.platformio/packages/framework-mbed/tools/libraries.py", line 25:
    from tools.tests import TEST_MBED_LIB, DEFAULT_SUPPORT
  File "/home/torrey/.platformio/packages/framework-mbed/tools/tests.py", line 18:
    from past.builtins import cmp
  File "/home/torrey/.platformio/packages/framework-mbed/platformio/package_deps/py3/past/builtins/__init__.py", line 54:
    from past.builtins.misc import (apply, chr, cmp, execfile, intern, oct,
  File "/home/torrey/.platformio/packages/framework-mbed/platformio/package_deps/py3/past/builtins/misc.py", line 45:
    from imp import reload
==================================================================== [FAILED] Took 0.41 seconds ====================================================================
Environment    Status    Duration
vitalsMBED     FAILED    00:00:00.413
============================================================== 1 failed, 0 succeeded in 00:00:00.413 ==============================================================
 *  The terminal process "platformio 'run', '--environment', 'vitalsMBED'" terminated with exit code: 1.
Here is the platformio.ini file. I am building this while in the vitalsMBED environment:
[env:mcu_node]
platform = nxplpc
board = lpc1768
framework = mbed
build_src_filter = +<mcu_node/> +<common/> +<arch/mbed.cpp>
monitor_port = /dev/ttyACM0
upload_port = /media/torrey/MBED
[env:vitalsMBED]
platform = nxplpc
board = lpc1768
framework = mbed
build_src_filter = +<vitals_node/mbedVitals.cpp> +<common/> +<arch/mbed.cpp>
#lib_deps =
#    mbed-hudakz/millis
[env:telemetry_node]
board = uno
build_src_filter = +<telemetry_node/> +<common/> +<arch/arduino.cpp>
    arkhipenko/TaskScheduler @ 3.7.0
    sandeepmistry/CAN @ 0.3.1
upload_port = /dev/ttyACM0
[env:vitals_node]
board = uno
build_src_filter = +<vitals_node/main.cpp> +<common/> +<arch/arduino.cpp> +<arch/arduino.hpp>
[env:solovitals_node]
board = uno
build_src_filter = +<vitals_node/mainsolo.cpp> +<common/> +<arch/arduino.cpp> +<arch/arduino.hpp>
[env:sensor_node]
board = uno
build_src_filter = +<vitals_node/sensor.cpp> +<common/> +<arch/arduino.cpp> +<arch/arduino.hpp>
monitor_port = /dev/ttyACM1
upload_port = /dev/ttyACM1
I have temporarily commented out my code so that the only code present is in the mbedVitals.cpp file.:
#include <mbed.h>
int main(){
VSCode highlights the #include <mbed.h> line claiming “include errors detected, cannot open source file mbed.h”. I also tried writing #include “mbed.h,” but that resulted in the same thing. So, here are the project IntelliSence Configurations:
/home/torrey/Documents/ProveMila-embedded/include
/home/torrey/Documents/ProveMila-embedded/src
/home/torrey/Documents/ProveMila-embedded/.pio/libdeps/solovitals_node/CAN/src
/home/torrey/.platformio/packages/framework-arduino-avr/libraries/SPI/src
/home/torrey/Documents/ProveMila-embedded/.pio/libdeps/solovitals_node/TaskScheduler/src
/home/torrey/.platformio/packages/framework-arduino-avr/cores/arduino
/home/torrey/.platformio/packages/framework-arduino-avr/variants/standard
/home/torrey/.platformio/packages/framework-arduino-avr/libraries/EEPROM/src
/home/torrey/.platformio/packages/framework-arduino-avr/libraries/HID/src
/home/torrey/.platformio/packages/framework-arduino-avr/libraries/SoftwareSerial/src
/home/torrey/.platformio/packages/framework-arduino-avr/libraries/Wire/src
Mhm something is not right here. Since PlatformIO core version 6.1.12 (release notes), it supports Python 3.12, but when installing the PlatformIO core regularly through the VSCode extension, then per https://github.com/platformio/platformio-vscode-ide/releases it should use Python 3.11. Which per this issue should still be compatible with the imp library that mbed-os builds need.
Maybe @ivankravets can confirm that that is the used Python version?
The issue comes from the Mbed framework. It seems that the latest version of Mbed framework does not support Python 3.12. What is more, Arm dropped support for the Mbed framework. So, no new features/bug fixes.
As the solution, you can try pyenv tool. I use it frequently to test PIO Core against different Python versions. You can install Python 3.9, and later use it to install PIO Core.
  1. Install pyenv and python3.9
  2. Download the installer script Installer Script (Recommended) — PlatformIO latest documentation
  3. Remove ~/.platformio/penv folder
  4. Run ~/.pyenv/versions/3.9.XXXXXX/bin/python get-platformio.py
  5. Restart VSCode.
Did it help?
Thank you so much! It is now working.
Hi there,
I just ran into the same problem with Python 3.12 on Windows, here is another workaround to get Mbed to work with PlatformIO and Python 3.12 (+?) that might work on Linux:
  • In the file C:\Users\YOUR_NAME\.platformio\packages\framework-mbed\platformio\package_deps\py3\past\builtins\misc.py:
  • For the next distutils error:
    • Install setuptools to get the missing package : pip install setuptools.
    • The distutils standard lib has been removed as of Python 3.12: https://peps.python.org/pep-0632/
I can’t find the misc.py file on github to open a suggestion, but maybe it’s not an ideal edit …
But as @ivankravets says: Arm dropped support some time ago, MbedOS and related build tools are outdated, and it is difficult to find the right “way” to install MbedOs for each new Python version (especially using the Arm Mbed CLI tool).
