Unable to build any project - Help me
Hi everybody!
I am tring to fix a problema with my installation of PlatformIO over VS Code for two days. I coded, builded and uploaded Arduino Mega project for about one year. I don’t know why it not works anymore since Friday.
Trying to fix the problema, I have reinstalled it for about ten times, change versions… but i ever get the same error.
The envoriment is Windows 10, VS Code 1.44.2, PlatformIO 1.10.0.
Here a very basic code (and any other one) that not works (main.cpp file on /src folder):
int a;
  a = 5;
The platformio.ini file is:
[env:megaatmega2560]
board = megaatmega2560
When I build the project, this error happens:
PS C:\Users\Dev\Documents\PlatformIO\Projects\Test> C:\Users\Dev\.platformio\penv\Scripts\platformio.exe run -v
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR 2.0.0 > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
 - framework-arduino-avr 5.0.0
Found 6 compatible libraries
avr-g++ -o .pio\build\megaatmega2560\firmware.elf -Os -mmcu=atmega2560 -Wl,--gc-sections -flto -fuse-linker-plugin .pio\build\megaatmega2560\src\main.cpp.o -L.pio\build\megaatmega2560 -Wl,--start-group .pio\build\megaatmega2560\libFrameworkArduinoVariant.a .pio\build\megaatmega2560\libFrameworkArduino.a -lm -Wl,--end-group
C:\Users\Dev\AppData\Local\Temp\ccIKBZ2U.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x0): undefined reference to `init'
*** [.pio\build\megaatmega2560\firmware.elf] Error 1
o_O sounds like startup code cannot find the framework files? I suggest that you open a Windows explorer, navigate to C:\Users\Dev\.platformio\packages and delete every folder found inside this repository. PlatformIO will re-download everything upon the next compile, in a hopefully clean version.
Hi @maxgerhardt, thanks for your help!
I just deleted every folders inside packages. Alfter, I open Visual Code, it reloads a lot of things. But, after it, I got this two messages before build:
#include errors detected. Please update your includePath. Squiggles are disabled for this translation unit (C:\Users\Dev\Documents\PlatformIO\Projects\Test\src\main.cpp).
cannot open source file “Arduino.h”
So, i thinked it is was caused for the deleted packages.
I tryed again to build and got the other problem:
C:\Users\Dev.platformio\penv\Scripts\platformio.exe run <
PackageManager: Installing toolchain-atmelavr @ ~1.50400.0
toolchain-atmelavr @ 1.50400.190710 has been successfully installed!
PackageManager: Installing framework-arduino-avr @ ~5.0.0
framework-arduino-avr @ 5.0.0 has been successfully installed!
CorePackageManager: Installing tool-scons @ ~3.30102.0
tool-scons @ 3.30102.0 has been successfully installed!
CONFIGURATION: Redirecting...
  • framework-arduino-avr 5.0.0
  • toolchain-atmelavr 1.50400.190710 (5.4.0)
    Scanning dependencies…
    Compiling .pio\build\megaatmega2560\FrameworkArduino\wiring.c.o
    *** [.pio\build\megaatmega2560\FrameworkArduino\wiring.c.o] Error -1
    =================================================== [FAILED] Took 80.15 seconds ===================================================
And the "#include <Arduino.h> is red underlined and the two problems still is showed.
Yes, the Intellisense errors are temporary for until the files are redownloaded.
Is there any antivirus program running on your PC, which you could temporarily disable? I don’t see why that should fail now.
Also can you give the result of a “Verbose Build” within VSCode?
@maxgerhardt, the problem was caused by the antivirus.
I don’t believe it was so simple problem! More than twety hours lost.
But it is a kind of surprises caused by multiple users machine. My daugther has installed a new antivirus.
Thanks a lot, dude!!!
ive same problem like that, but when i disabling my antivirus,instead i deleted one of my antifirus. and i disabled kaspersky antivirus. but still failed to build.
> Executing task: C:\Users\ridho\.platformio\penv\Scripts\platformio.exe run <
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR 2.1.0 > Arduino Uno
Linking .pio\build\uno\firmware.elf
C:\Users\ridho\AppData\Local\Temp\ccavXMa6.ltrans0.ltrans.o: In function `main':
*** [.pio\build\uno\firmware.elf] Error 1
==================================================== [FAILED] Took 2.59 seconds ====================================================
C:\Users\ridho\AppData\Local\Temp\cceafxca.ltrans0.ltrans.o: In function `main':
==================================================== [FAILED] Took 2.14 seconds ====================================================
or what should i do?
Still seems like broken framework files to me. Try to delete C:\Users\<User>\.platformio\packages and retry.
