Umm, im trying to use PlatformIO on termux, but when I build it it gives me this error
┌─╼[WetlandCraft@termux]-[~/espstuff]
platformio run
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (4.2.1) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
 - tool-esptool @ 1.413.0 (4.13)
 - tool-esptoolpy @ 1.30000.201119 (3.0.0)
 - toolchain-xtensa @ 1.40802.0 (4.8.2)
Found 0 compatible libraries
AttributeError: 'SConsEnvironment' object has no attribute 'ElfToBin':
  File "/data/data/com.termux/files/usr/lib/python3.11/site-packages/platformio/builder/main.py", line 173:
  File "/data/data/com.termux/files/home/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 612:
  File "/data/data/com.termux/files/home/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 279:
  File "/data/data/com.termux/files/home/.platformio/platforms/espressif8266/builder/main.py", line 247:
    target_firm = env.ElfToBin(
================== [FAILED] Took 2.60 seconds ==================
Looks a little bit like this solved problem. Probably your platformio.ini has no framework entry.
