UIPEthernet by Zoltan Hudak for MBED
The library UIPEthernet by Zoltan Hudak for MBED is not compiled.
Gives error message
compilation terminated.
*** [.pioenvs\nucleo_f103rb\liba1a\UIPEthernet_ID2813\UIPClient.o] Error 1
What exact example are you compiling? What’s your platformio.ini? What’s the full error message? The “compilation terminated” just tells us that something fatal before that happened.
Platformio.ini
[env:nucleo_f103rb]
platform = ststm32
board = nucleo_f103rb
framework = mbed
lib_deps = 2813
example
  • In this example the HTTP request (text) received from a browser is echoed (sent back) to the browser.
  • Ethernet connection is via an ENC28J60 Ethernet board driven by the UIPEthernet library
    #include “mbed.h”
    #include “UIPEthernet.h”
    #include “UIPServer.h”
    #include “UIPClient.h”
#define DHCP    1   // if you'd like to use static IP address comment out this line
// MAC address must be unique within the connected network. Modify as appropriate.
const uint8_t   MY_MAC[6] = { 0x00, 0x01, 0x02, 0x03, 0x04, 0x05 };
const uint16_t  MY_PORT = 80;   // for HTTP connection
Serial  pc(USBTX, USBRX);
#if defined(TARGET_LPC1768)
UIPEthernet    uIPEthernet(D11, D12, D13, D10);          // mosi, miso, sck, cs
#elif defined(TARGET_NUCLEO_F103RB) || defined(TARGET_NUCLEO_L152RE) || defined(TARGET_NUCLEO_F030R8)  \
   || defined(TARGET_NUCLEO_F401RE) || defined(TARGET_NUCLEO_F302R8) || defined(TARGET_NUCLEO_L053R8)  \
   || defined(TARGET_NUCLEO_F411RE) || defined(TARGET_NUCLEO_F334R8) || defined(TARGET_NUCLEO_F072RB)  \
   || defined(TARGET_NUCLEO_F091RC) || defined(TARGET_NUCLEO_F303RE) || defined(TARGET_NUCLEO_F070RB)  \
   || defined(TARGET_KL25Z ) || defined(TARGET_KL46Z) || defined(TARGET_K64F) || defined(TARGET_KL05Z) \
   || defined(TARGET_K20D50M) || defined(TARGET_K22F) \
   || defined(TARGET_NRF51822) \
   || defined(TARGET_RZ_A1H)
EthernetServer  myServer = EthernetServer(MY_PORT);
int main(void)
#if defined(DHCP)
    pc.printf("Searching for DHCP server..\r\n");
    if (uIPEthernet.begin(MY_MAC) != 1) {
        pc.printf("No DHCP server found.\r\n");
        pc.printf("Exiting application.\r\n");
        return 0;
    pc.printf("DHCP server found.\r\n");
#else
    // IP address must be unique and compatible with your network.
    const IPAddress MY_IP(192, 168, 1, 181);    //  Change as appropriate.
    uIPEthernet.begin(MY_MAC, MY_IP);
    pc.printf("Local IP = %s\r\n", uIPEthernet.localIP().toString());
    myServer.begin();
    while (1) {
        char            echoHeader[256];
        EthernetClient  client = myServer.available();
        if (client) {
            size_t  size = client.available();
            if (size > 0) {
                char*   buf = (char*)malloc(size);
                size = client.read((uint8_t*)buf, size);
                if (buf[0] == 'G' && buf[1] == 'E' && buf[2] == 'T') {
                    pc.printf("GET request received:\n\r");
                    pc.printf(buf);
                    sprintf
                        echoHeader,
                        "HTTP/1.1 200 OK\r\nContent-Length: %d\r\nContent-Type: text\r\nConnection: About to close\r\n\r\n",
                        size
                    client.write((uint8_t*)echoHeader, strlen(echoHeader));
                    client.write((uint8_t*)buf, size);
                    pc.printf("Echo done.\r\n");
                free(buf);
fatal error:
.piolibdeps\UIPEthernet_ID2813/Udp.h:38:10: fatal error: IPAddress.h: No such file or directory
Trying to add #include “IPAddress.h”, but exactly error.
In the mbed compiler (online) compiles normally.
