Very new to the 3D printing scene, Attempting to build Marlin firmware 2.1.2.2 with platformio and auto build marlin in VS code. I have to #include u8glib-hal.h in order for the LCD to receive the required library. I did that, after installing U8glib-Hal.h
However whenever I attempt to compile the results I error out, with platformio stating it is unable to find the recently installed library. (I did modify the platformio.ini to correspond to the u8glib library and will post below)
ERROR below:
In file included from buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/MarlinConfigPre.h:39:0,
from buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/MarlinConfig.h:28,
from buildroot/share/PlatformIO/scripts/common-dependencies.h:29:
e:\users\andrew\desktop\3d printing\marlin-2.1.2.2\marlin\configuration.h:1:10: fatal error: U8glib-HAL.h: No such file or directory
vvv using includes in main configuration file.
#include <U8glib-HAL.h>
#include <U8glibPrint.h>
#include <U8glibPrintable.h>
platformio.ini
[platformio]
src_dir = Marlin
boards_dir = buildroot/share/PlatformIO/boards
default_envs = mega2560
include_dir = Marlin
extra_configs =
Marlin/config.ini
ini/avr.ini
ini/due.ini
ini/esp32.ini
ini/features.ini
ini/lpc176x.ini
ini/native.ini
ini/samd21.ini
ini/samd51.ini
ini/stm32-common.ini
ini/stm32f0.ini
ini/stm32f1-maple.ini
ini/stm32f1.ini
ini/stm32f4.ini
ini/stm32f7.ini
ini/stm32h7.ini
ini/stm32g0.ini
ini/teensy.ini
ini/renamed.ini
[common]
build_flags = -g3 -D__MARLIN_FIRMWARE__ -DNDEBUG -DU8G_HAL_LINKS
-fmax-errors=5
extra_scripts =
pre:buildroot/share/PlatformIO/scripts/configuration.py
pre:buildroot/share/PlatformIO/scripts/common-dependencies.py
pre:buildroot/share/PlatformIO/scripts/common-cxxflags.py
pre:buildroot/share/PlatformIO/scripts/preflight-checks.py
post:buildroot/share/PlatformIO/scripts/common-dependencies-post.py
lib_deps = marlinfirmware/U8glib-HAL @ ^0.5.4
default_src_filter = +<src/*> -<src/config> -<src/tests>
-<src/lcd/HD44780> -<src/lcd/dogm> -<src/lcd/TFTGLCD> -<src/lcd/tft> -<src/lcd/tft_io>
-<src/lcd/e3v2> -<src/lcd/menu> -<src/lcd/extui> -<src/lcd/touch>
-<src/lcd/lcdprint.cpp>
-<src/HAL>
+<src/HAL/shared>
-<src/HAL/shared/backtrace>
-<src/HAL/shared/cpu_exception>
-<src/HAL/shared/eeprom_if_i2c.cpp>
-<src/HAL/shared/eeprom_if_spi.cpp>
-<src/feature>
only included the modified portion of platformio.ini, Could anyone give me some insight as to what the issue might be here?
