I try to build a program with platformio. It builds fine with the ‘normal’ esp32 environment.
- framework-espidf @ 3.40403.0 (4.4.3)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40400.0 (4.4.0)
- tool-ninja @ 1.7.1
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
Found 0 compatible libraries
Generating project linker script .pio/build/esp32dev/sections.ld
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
*** [checkprogsize] TypeError : unsupported operand type(s) for +: 'int' and 'str'
File "/home/wvdakker/.platformio/packages/tool-scons/scons-local-4.4.0/SCons/Action.py", line 1318, in execute
result = self.execfunction(target=target, source=rsources, env=env)
File "/home/wvdakker/.platformio/platforms/espressif32/builder/main.py", line 333, in <lambda>
lambda source, target, env: _update_max_upload_size(env),
File "/home/wvdakker/.platformio/platforms/espressif32/builder/main.py", line 143, in _update_max_upload_size
_parse_size(p["size"]) for p in _parse_partitions(env)
File "/home/wvdakker/.platformio/platforms/espressif32/builder/main.py", line 129, in _parse_partitions
next_offset = _parse_size(partition["offset"]) + _parse_size(
TypeError: unsupported operand type(s) for +: 'int' and 'str'
My partitions.csv look like
# Name, Type, SubType, Offset, Size, Flags
# Note: if you change the phy_init or app partition offset, make sure to change the offset in Kconfig.projbuild
nvs, data, nvs, 0x9000, 0x4000
otadata, data, ota, 0xd000, 0x2000
phy_init, data, phy, 0xf000, 0x1000
ota_0, 0, ota_0, 0x10000 , 0x1C0000
ota_1, 0, ota_1, 0x1D0000, 0x1C0000
device, 0x40, 0, , 0x1000
stations, 0x41, 0, , 0X10000
device1, 0x42, 0, , 0x1000
hardware, data, nvs, , 0x3000
Any clue what causes this error?
