Hello:
Recently I changed the directory structure for my PIO projects, so I wanted to change the default projects dir in PlatformIO.
I opened a terminal (in platformIO) and typed the command…
pio settings set projects_dir /home/mark/Documents/1_Programming/1_PlatformIO
This returned with…
Name Current value [Default] Description
projects_dir /home/mark/Documents/1_Programming/1_PlatformIO Default location for PlatformIO projects (PlatformIO Home)
[/home/mark/Documents/PlatformIO/Projects]
The bottom location is in yellow.
The second part “/home/mark/Documents/PlatformIO/Projects“ shouldn’t exist.
What is going on here, and how do I fix it?
Thanks, Mark.
PS. I don’t know what is going on with the forum changing the colors in the code here, but in reality, all of the response is in black and white except the afore mentioned yellow part.
