In certain cases the uninitialized variable warning is unnecessary and I would like to suppress this warning like <pragma warn-off=uninitialized_variable>
Code is in c++
I tried the
build_unflags =
-Wmaybe-uninitialized
in platformio.ini but it didn’t help.
Is there any opportuinity to place some inline hint like
/// <-W maybe-uninitialized>
int intentionally_not_initialized_variable;
Thanks
Yes, per GCC manuals (example).
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "maybe-uninitialized"
#pragma GCC diagnostic pop
Are you sure the compiler flags had -Wmaybe-uninitialized in them to begin with? If not, this is effectless. That warning category may have been activated by something like -Wall, -Wextra, etc. If you want to supress a specific warning, you should use the -Wno-<warning type> flag instead.
build_flags = -Wno-maybe-uninitialized
Again, all of this is written in
Thanks a lot, I’ll do that.
