Hello, all,
I have a problem with delivering byte data over RS485 channel:
The hardware is costructed from two identical self-designed PCBs that contain ESP32 and SP3485. Ther ESP32 uses D6 as Tx, D7 as Rx (there is a voltage divider to reduce from 5V to 3.3V levels)) and D9 as DE/!RE. The target, after finishing the testing and integration, is to communicate with meteorological sensors, so the protocol is mandatory. I tried to terminate the RS485 lines but the low transmission rate (9600 baud) and the short distance (5cm – 2") implied that they are not needed.
The transmitter code was taken from an example:
bool tx485 (const uint8_t *buf, uint8_t len){
digitalWrite(rtsPin, true); // Enable transmitter, disable receiver
delayMicroseconds(_turnaround); // Allow the hardware RS485 transciever to stabilize
uint8_t txDataSize = len;
Serial1.write(buf, len); // Send the reading command
Serial1.flush();
digitalWrite(rtsPin, false); // Disable transmitter, Enable receiver
return (txDataSize == len);
Where buf is 8 bytes long and rs485txDir is boolean high. The transmitted data is { 0x01, 0x03, 0x00, 0x00, 0x00, 0x02, 0xc4, 0x0b }. Using an osciloscope I verified that all 8 character are sent correctly.
The receiver code:
bool rx485 (char *buf, uint8_t lenLimit){
uint8_t rxPtr = 0;
while (Serial1.available() > 0){
***if(rxPtr < lenLimit){*** ***buf\[rxPtr++\] = Serial1.read(); // Read the next character*** ***rxPtr++;*** ***}*** ***else Serial1.read(); // "waist" extra characters, if any.***}
return(lenLimit == rxPtr);
The receiver gets only 2 bytes instead of 8; all received bytes are positions 2 and 0. However, it looks like the receivber doesn’t synchronize on the package start.
I tried to add delays, split both sides into 1-byte messages and some other desparate ideas. Any hint will be warmly acdepted.
Regards
Yona
