I’m trying to build for a Lora-E5 board from seeed.
This is what I have tried so far:
I’ve cloned platform-ststm32/examples/mbed-rtos-custom-target at develop · platformio/platform-ststm32 · GitHub
and used the examples/mbed-rtos-custom as a base for my project.
Then I have added custom_targets.json to the root of bed-rtos-custom-target, and tried building.
But the build errors with
Detected custom target file
mbed build API internal error
target LORA_E5 has an incomplete target definition
This is my custom_targets.json
"CUSTOM_NUCLEO_L452RE_MBED": {
"inherits": [
"MCU_STM32"
"core": "Cortex-M4F",
"extra_labels_add": [
"STM32L4"
"config": {
"clock_source": {
"help": "Mask value : USE_PLL_HSE_EXTC (need HW patch) | USE_PLL_HSE_XTAL (need HW patch) | USE_PLL_HSI | USE_PLL_MSI",
"value": "USE_PLL_MSI",
"macro_name": "CLOCK_SOURCE"
"lpticker_lptim": {
"help": "This target supports LPTIM. Set value 1 to use LPTIM for LPTICKER, or 0 to use RTC wakeup timer",
"value": 1
"macros_add": [
"STM32L452xx",
"MBED_TICKLESS",
"EXTRA_IDLE_STACK_REQUIRED",
"MBED_SPLIT_HEAP"
"overrides": {
"lpticker_delay_ticks": 0
"detect_code": [
"1234"
"device_has_add": [
"ANALOGOUT",
"CRC",
"SERIAL_ASYNCH",
"CAN",
"TRNG",
"FLASH",
"MPU"
"device_name": "STM32L452RETx",
"bootloader_supported": true
"LORA_E5": {
"inherits": [
"MCU_STM32WLE5xC"
"device_name": "STM32WLE5JCIx"
"LORA_E5_BREAKOUT": {
"inherits": [
"LORA_E5"
"macros_add": [
"LED1=PB_5",
"LED2=PB_10",
"BUTTON1=PB_13"
"LORA_E5_MINI": {
"inherits": [
"LORA_E5"
"macros_add": [
"LED1=PB_5",
"BUTTON1=PB_13"
"LORA_E5_DEV_BOARD": {
"inherits": [
"LORA_E5"
"macros_add": [
"LED1=PB_5",
"EN_3V3=PA_9",
"EN_5V=PB_10",
"BUTTON1=PB_13",
"BUTTON2=PA_0",
"RS485_REDE=PB_4"
And my platform.ini
[env:lora_e5]
platform = ststm32
framework = mbed
board = lora_e5_dev_board
-I$PROJECT_SRC_DIR/TARGET_STM32WL
-I$PROJECT_SRC_DIR/TARGET_STM32WL/device
-I$PROJECT_SRC_DIR/TARGET_STM32WL/TARGET_LORA_E5
and under boards/lora_e5_dev_board.json
"build": {
"core": "stm32",
"cpu": "cortex-m4",
"extra_flags": "-DSTM32WLxx -DSTM32WLE5xx",
"f_cpu": "48000000L",
"framework_extra_flags": {
"arduino": "-DUSE_CM4_STARTUP_FILE"
"mcu": "stm32wl55jc",
"product_line": "STM32WL55xx",
"variant": "STM32WLxx/WL54JCI_WL55JCI_WLE4J(8-B-C)I_WLE5J(8-B-C)I"
"debug": {
"default_tools": [
"stlink"
"jlink_device": "STM32WL55JC",
"onboard_tools": [
"stlink"
"openocd_target": "stm32wlx",
"svd_path": "STM32WL5x_CM4.svd"
"frameworks": [
"arduino",
"zephyr",
"mbed"
"name": "LORA E5",
"upload": {
"maximum_ram_size": 65536,
"maximum_size": 262144,
"protocol": "stlink",
"protocols": [
"jlink",
"cmsis-dap",
"stlink",
"mbed"
"url": "https://www.seeedstudio.com/LoRa-E5-Wireless-Module-p-4745.html",
"vendor": "seeed"
