I have an ESP-Prog and an ESP32, and I want to debug a broken program.
The Prog is wired in to the ESP32.
When I try to start debugging, I get this:
No debug task appears in the task list when I choose Configure.
.ini is set up for debug:
debug_tool = esp-prog
SD...```
This is the debug console output:
undefinedC:\Users\joema.platformio\packages\toolchain-xtensa-esp32\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
Reading symbols from c:\Users\joema\Documents\PlatformIO\Projects\SPIFFS_Plot_Chart_32.pio\build\esp32dev\firmware.elf…
PlatformIO: debug_tool = cmsis-dap
Open On-Chip Debugger v0.11.0-esp32-20220411 (2022-04-11-08:48)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: unable to find a matching CMSIS-DAP device
Assertion failed!
Program: C:\Users\joema.platformio\packages\tool-openocd-esp32\bin\openocd.exe
File: …/src/jtag/core.c, Line 338
Expression: jtag_trst == 0
Remote communication error. Target disconnected.: Success.
That’s weird, why it would it look for a CMSIS-DAP device if you have debug_tool = esp-prog set – do you have multiple projects open?
I’ve engineered my habit so there’s only one program open when I’m working on it. If I’m cutting and pasting and making a mess, there can be several open. But not if I’m trying to learn debugging, for example.
I don’t know what any of that means. CMSIS?
What can I do about it?
I don’t know enough to tell if it’s working, but I can tell it isn’t working.
This line says its from a project called “SPIFFS_Plot_Chart_32”. Your screenshot shows you have the platformio.ini open from a project ending in “_Dashboard_Receiver”. That doesn’t match. Are you 100% sure you’re editing the platformio.ini of the opened project and you in the debug side pannel, you select the right “PIO Debug” target that has the project name in it?
I have a similar error, I’m using PlatformIO within VS Code for the first time and I’am load my led_blink, my code ran on the board without errors, but it generated this error when I try to debug it. I have only this project open.
The message seems to have something to do with this: ‘adapter speed’ not ‘adapter_khz’.
Could someone help me please?
Thank you.
Can you explicitly set
in the platformio.ini and see if the outupt changes?
What’s the content of the platformio.ini now?
I put it now:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
I modified as you said, but it generated a new error as shown in the photo:
It can’t find a connected ESP-Prog device.
Do you have an ESP-Prog device connected to the ESP32 via the JTAG cables like Low-cost ESP32 In-circuit Debugging | by Manuel Bl. | Medium shows? Without additional hardware, debugging the ESP32 is not possible in PlatformIO.
It’s all explained now.
I will buy one.
Thanks
