im trying to get core working on my Nixos system but when i try to run pio run it says that pyserial is not installed while it is
output:
Beast[~/GIT/Personal/esp32_test] > pio run
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
PLATFORM: Espressif 32 (6.4.0) > Espressif ESP32 Dev Module
- framework-espidf @ 3.50101.230828 (5.1.1)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.7.1
- tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
- tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-xtensa-esp32 @ 12.2.0+20230208
Found 0 compatible libraries
Building .pio/build/esp32dev/bootloader.bin
Pyserial is not installed for /nix/store/pzf6dnxg8gf04xazzjdwarm7s03cbrgz-python3-3.10.12/bin/python3.10. Check the README for installation instructions.
File "/home/nicolaivds/.platformio/packages/tool-esptoolpy/esptool.py", line 31, in <module>
import esptool
File "/home/nicolaivds/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 41, in <module>
from esptool.cmds import (
File "/home/nicolaivds/.platformio/packages/tool-esptoolpy/esptool/cmds.py", line 14, in <module>
from .bin_image import ELFFile, ImageSegment, LoadFirmwareImage
File "/home/nicolaivds/.platformio/packages/tool-esptoolpy/esptool/bin_image.py", line 14, in <module>
from .loader import ESPLoader
File "/home/nicolaivds/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 30, in <module>
import serial
ModuleNotFoundError: No module named 'serial'
*** [.pio/build/esp32dev/bootloader.bin] Error 1
================================================ [FAILED] Took 3.20 seconds ================================================
here is my shell.nix file:
{ pkgs ? import <nixpkgs> {} }:
let
my-python = pkgs.python3;
my-python-packages = my-python.withPackages (ps: with ps; [
pip
setuptools
pyserial
in
pkgs.mkShell {
buildInputs = [
my-python-packages
] ++ (with pkgs; [
platformio-core
esptool
shellHook = ''
PYTHONPATH=${my-python-packages}/${my-python-packages.sitePackages}
i must say where the pio run command looks for pyserial is difrent from my $PYTHONPATH
Beast[~/GIT/Personal/esp32_test] > echo $PYTHONPATH
/nix/store/sl1ga1nap5lkz5is9gc45xvvyx7r6rcf-python3-3.10.12-env/lib/python3.10/site-packages
does any one have any idea what i am missing ?
