Not sure if this is the best place for this but as I can’t seem to find any support for VASM so figured someone might know the answer to this.
VASM is a 6502 assembler. I’m trying to configure tasks.json which I have more or less working but running into a strange issue when trying to specify the output file.
If I run this from the terminal it works.
vasm6502_oldstyle -Fbin -o demo.bin demo.s -dotdir
However with this in the tasks.json
"version": "2.0.0",
"tasks": [
"label": "vasm",
"type": "shell",
"command": "/usr/bin/vasm6502_oldstyle",
"args": [
"-Fbin",
"-o demo.bin",
"${file}",
"-dotdir"
"group": {
"kind": "build",
"isDefault": true
"problemMatcher": []
I get
error 15: unknown option <-o demo.bin>
The terminal process "/usr/bin/bash '-c', '/usr/bin/vasm6502_oldstyle -Fbin '-o demo.bin' /home/greg/nfs/PlatformIO/DevEnvironmentDemo-main/demo.s -dotdir'" failed to launch (exit code: 1).
Not sure why is works on the CLI but not from VSC.
Is there something I’m missing in my json file?
If I exclude the “-o demo.bin” it works but then defaults to a filename of a.out.
Guess worst case I could run some postinst script to rename the file?
