I have an SKr v1.3 running Marlin 2.0.7 and I needed to update 2 lines of code and recompile it. My VScode and PlatformIO is up to date but it does not like this old version of Marlin. I have been searching this forum for 2 days now for a solution and while I do see some stuff that is helpful I cannot find a specific solution to this problem. Before I even try to compile I get this in the Output tab of VScode:
Warning! Ignore unknown configuration option `monitor_flags` in section [env]
Warning! `src_filter` configuration option in section [env:DUE] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:SAMD51_grandcentral_m4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:STM32F4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:STM32F7] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:malyan_M300] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:esp32] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy31] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy35] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy36] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy41] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_build_flags` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_flags` instead
Warning! `src_filter` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:include_tree] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Resolving LPC1768 dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Warning! Ignore unknown configuration option `monitor_flags` in section [env]
Processing LPC1768 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.3.zip; board: nxp_lpc1768; framework: arduino)
SyntaxError: source code string cannot contain null bytes
========================== [FAILED] Took 1.16 seconds ==========================
Environment Status Duration
LPC1768 FAILED 00:00:01.157
==================== 1 failed, 0 succeeded in 00:00:01.157 ====================
I get this when trying to compile:
* Executing task: C:\Users\kortt\.platformio\penv\Scripts\platformio.exe run
========================================================================= [FAILED] Took 1.39 seconds =========================================================================
LPC1768 FAILED 00:00:01.386
==================================================================== 1 failed, 0 succeeded in 00:00:01.386 ====================================================================
* The terminal process "C:\Users\kortt\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Can anyone help or point me in the right place if this has been covered?
Thanks so much!
