I try to switch from Arduino IDE to Visual Studio Code using PlatformIO extension.
All my Arduino projects compile except one !
The one that does not compile is a small project with the Trinket from Adafruit (= ATiny85 under the hood).
The error I get has to do with the particular library I intend to use called “TrinketKeyboard”.
(The library shall not be confused with the TrinketKeyboar for Trinket-PRO devices !!).
Again, on the Arduino-IDE everything works fine. I installed the library on the Arduino IDE by importing a .zip-file.
The .zip-file import option obviously does not exist on the PlatformIO. There, I simply copy/paste the very same library into the lib-folder of my workspace. (like I did for all the other perfectly fine running PIO projects…).
However, the TrinketKeyboard Library does not work on PlatformIO and I am working on it since 4 hours. Now I give up unless somebody has a brillant idea
The error message says:
Scanning dependencies…
Compiling .pioenvs/trinket5/src/Trinket_2Button.ino.cpp.o
Compiling .pioenvs/trinket5/lib269/TrinketKeyboard/usbdrv/usbdrvasm.asm.o
avr-as: unrecognized option `-x’
*** [.pioenvs/trinket5/lib269/TrinketKeyboard/usbdrv/usbdrvasm.asm.o] Error 1
Can you post your full platformio.ini
and lnk to the library? I’m only finding PlatformIO Registry which isn’t what you have according to you. What example code are you running?
Alright I guess you mean Adafruit-Trinket-USB/TrinketKeyboard at master · adafruit/Adafruit-Trinket-USB · GitHub .
I just compiled this without problems by doing:
download the full zip file of the repository
extract the TrinketKeyboard
folder into the libs
folder of the PIO project
open lib/TrinketKeyboard/usbdrv/usbdrvasm.asm
and remove the last line end
copy the lib/TrinketKeyboard/TrinketKeyboardExample/TrinketKeyboardExample.ino
to src/main.cpp
(important).
build
Processing trinket5 (platform: atmelavr; board: trinket5; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/trinket5.html
PLATFORM: Atmel AVR > Adafruit Trinket 5V/16MHz
HARDWARE: ATTINY85 16MHz 512B RAM (8KB Flash)
Framework incompatible library C:\Users\Maxi\Documents\stackoverflow_testing\.piolibdeps\SX1272Lib_ID2756
Framework incompatible library C:\Users\Maxi\Documents\stackoverflow_testing\.piolibdeps\SoftwareSerial_ID2728
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Collected 43 compatible libraries
|-- <TrinketKeyboard> (C:\Users\Maxi\Documents\stackoverflow_testing\lib\TrinketKeyboard)
avr-gcc -x assembler-with-cpp -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -Ilib\TrinketKeyboard -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 -c -o .pioenvs\trinket5\lib971\TrinketKeyboard\usbdrv\usbdrvasm.asm.o lib\TrinketKeyboard\usbdrv\usbdrvasm.asm
avr-gcc-ar rc .pioenvs\trinket5\libFrameworkArduinoVariant.a
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\CDC.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\CDC.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\HardwareSerial.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\HardwareSerial.cpp
avr-gcc-ar rc .pioenvs\trinket5\lib971\libTrinketKeyboard.a .pioenvs\trinket5\lib971\TrinketKeyboard\TrinketKeyboard.cpp.o .pioenvs\trinket5\lib971\TrinketKeyboard\TrinketKeyboardC.c.o .pioenvs\trinket5\lib971\TrinketKeyboard\usbdrv\oddebug.c.o .pioenvs\trinket5\lib971\TrinketKeyboard\usbdrv\usbdrv.c.o .pioenvs\trinket5\lib971\TrinketKeyboard\usbdrv\usbdrvasm.S.o .pioenvs\trinket5\lib971\TrinketKeyboard\usbdrv\usbdrvasm.asm.o .pioenvs\trinket5\lib971\TrinketKeyboard\usbdrv_includer.c.o .pioenvs\trinket5\lib971\TrinketKeyboard\usbdrvasm_includer.S.o
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\HardwareSerial0.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\HardwareSerial0.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\HardwareSerial1.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\HardwareSerial1.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\HardwareSerial2.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\HardwareSerial2.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\HardwareSerial3.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\HardwareSerial3.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\IPAddress.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\IPAddress.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\PluggableUSB.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\PluggableUSB.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\Print.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\Print.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\Stream.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\Stream.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\Tone.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\Tone.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\USBCore.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\USBCore.cpp
In file included from C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\Tone.cpp:37:0:
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\Tone.cpp: In function 'void TIMER2_COMPA_vect()':
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\Tone.cpp:538:5: warning: 'TIMER2_COMPA_vect' appears to be a misspelled signal handler, missing __vector prefix [-Wmisspelled-isr]
ISR(TIMER2_COMPA_vect)
avr-gcc -o .pioenvs\trinket5\FrameworkArduino\WInterrupts.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\WMath.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WMath.cpp
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c: In function 'attachInterrupt':
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c:166:8: warning: #warning attachInterrupt may need some more work for this cpu (case 1) [-Wcpp]
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c: In function 'detachInterrupt':
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c:255:8: warning: #warning detachInterrupt may need some more work for this cpu (case 1) [-Wcpp]
In file included from C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c:29:0:
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c: In function 'INT1_vect':
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c:310:15: warning: 'INT1_vect' appears to be a misspelled signal handler, missing __vector prefix [-Wmisspelled-isr]
IMPLEMENT_ISR(INT1_vect, EXTERNAL_INT_1)
C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WInterrupts.c:310:1: note: in expansion of macro 'IMPLEMENT_ISR'
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\WString.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\WString.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\abi.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\abi.cpp
avr-gcc -o .pioenvs\trinket5\FrameworkArduino\hooks.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\hooks.c
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\main.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\main.cpp
avr-g++ -o .pioenvs\trinket5\FrameworkArduino\new.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\new.cpp
avr-gcc -o .pioenvs\trinket5\FrameworkArduino\wiring.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\wiring.c
avr-gcc -o .pioenvs\trinket5\FrameworkArduino\wiring_analog.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\wiring_analog.c
avr-gcc -o .pioenvs\trinket5\FrameworkArduino\wiring_digital.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\wiring_digital.c
avr-gcc -x assembler-with-cpp -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 -c -o .pioenvs\trinket5\FrameworkArduino\wiring_pulse.S.o C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\wiring_pulse.S
avr-gcc -o .pioenvs\trinket5\FrameworkArduino\wiring_pulse.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\wiring_pulse.c
avr-gcc-ranlib .pioenvs\trinket5\libFrameworkArduinoVariant.a
avr-gcc -o .pioenvs\trinket5\FrameworkArduino\wiring_shift.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny85 -DPLATFORMIO=30602 -DARDUINO_AVR_TRINKET5 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\Maxi\.platformio\packages\framework-arduinoavr\variants\trinket_tiny8 C:\Users\Maxi\.platformio\packages\framework-arduinoavr\cores\arduino\wiring_shift.c
avr-gcc-ranlib .pioenvs\trinket5\lib971\libTrinketKeyboard.a
avr-gcc-ar rc .pioenvs\trinket5\libFrameworkArduino.a .pioenvs\trinket5\FrameworkArduino\CDC.cpp.o .pioenvs\trinket5\FrameworkArduino\HardwareSerial.cpp.o .pioenvs\trinket5\FrameworkArduino\HardwareSerial0.cpp.o .pioenvs\trinket5\FrameworkArduino\HardwareSerial1.cpp.o .pioenvs\trinket5\FrameworkArduino\HardwareSerial2.cpp.o .pioenvs\trinket5\FrameworkArduino\HardwareSerial3.cpp.o .pioenvs\trinket5\FrameworkArduino\IPAddress.cpp.o .pioenvs\trinket5\FrameworkArduino\PluggableUSB.cpp.o .pioenvs\trinket5\FrameworkArduino\Print.cpp.o .pioenvs\trinket5\FrameworkArduino\Stream.cpp.o .pioenvs\trinket5\FrameworkArduino\Tone.cpp.o .pioenvs\trinket5\FrameworkArduino\USBCore.cpp.o .pioenvs\trinket5\FrameworkArduino\WInterrupts.c.o .pioenvs\trinket5\FrameworkArduino\WMath.cpp.o .pioenvs\trinket5\FrameworkArduino\WString.cpp.o .pioenvs\trinket5\FrameworkArduino\abi.cpp.o .pioenvs\trinket5\FrameworkArduino\hooks.c.o .pioenvs\trinket5\FrameworkArduino\main.cpp.o .pioenvs\trinket5\FrameworkArduino\new.cpp.o .pioenvs\trinket5\FrameworkArduino\wiring.c.o .pioenvs\trinket5\FrameworkArduino\wiring_analog.c.o .pioenvs\trinket5\FrameworkArduino\wiring_digital.c.o .pioenvs\trinket5\FrameworkArduino\wiring_pulse.S.o .pioenvs\trinket5\FrameworkArduino\wiring_pulse.c.o .pioenvs\trinket5\FrameworkArduino\wiring_shift.c.o
avr-gcc-ranlib .pioenvs\trinket5\libFrameworkArduino.a
avr-g++ -o .pioenvs\trinket5\firmware.elf -Os -mmcu=attiny85 -Wl,--gc-sections -flto -fuse-linker-plugin .pioenvs\trinket5\src\main.cpp.o -L.pioenvs\trinket5 -Wl,--start-group .pioenvs\trinket5\lib971\libTrinketKeyboard.a .pioenvs\trinket5\libFrameworkArduinoVariant.a .pioenvs\trinket5\libFrameworkArduino.a -lm -Wl,--end-group
MethodWrapper(["checkprogsize"], [".pioenvs\trinket5\firmware.elf"])
avr-objcopy -O ihex -R .eeprom .pioenvs\trinket5\firmware.elf .pioenvs\trinket5\firmware.hex
DATA: [== ] 20.9% (used 107 bytes from 512 bytes)
PROGRAM: [==== ] 40.0% (used 3274 bytes from 8192 bytes)
.pioenvs\trinket5\firmware.elf :
section size addr
.text 3246 0
.data 28 8388704
.bss 79 8388732
.comment 17 0
.note.gnu.avr.deviceinfo 60 0
.debug_aranges 160 0
.debug_info 1996 0
.debug_abbrev 1100 0
.debug_line 678 0
.debug_str 361 0
Total 7725
[SUCCESS] Took 15.51 seconds
Yes, you guessed the correct library !
One question to your suggested step #4 (i.e. copy the lib/TrinketKeybaord....
to screenshot/main.cpp
(Important)
How did you exactly mean that ? (I don’t know how to copy a file to a file ? Did you mean to replace the one file or did you mean to add the file at the same location ? Can you please clarify ?
Then, to be complete on the library we are talking about:
I did two changes to the library (the one that you correctly found as well) - (as these were necessary also inside the Arduino IDE for successful compilation)
Here are the two changes from the original library :
(…however, I don’t think they are relevant for my original question tough, …but simply for completeness reasons I state them here below…) :
Make sure that line 17 and 18 show the following:
#undef __SFR_OFFSET
#define __SFR_OFFSET 0 /* used by avr-libc's register definitions */
Make sure that line 73 shows the follwowing:
#if 0x41 < 0x40 /* This is an I/O address, use in and out */
If the two changes are not made, the TrinketKeyboard library will not compile (not for Arduino IDE and not for PlatformIO under VSCode).
Just copy th example ino
file to your src
folder and rename it to the cpp
extension. See file structure:
skuenstler:
#undef __SFR_OFFSET
I did not have to make these changes for it being able to compile… What PlatformIO version are you using? (pio --version
Since I am completely new to PlatformIO - silly question where do I type: pio --version
Under PIO Home it says: Home 2.0.0
Core 3.6.2
The two changes I stated were indeed also necessary for the Arduino IDE. I am not sure if it has to do with the fact that I am on an older MAC book (late 2013) or if it has something to do with the USB driver.
I will now try what you explained… Thank you very much.
I did move the example to the src folder and renamed it to main.cpp
But I get the very same error like the entire afternoon today:
My platform.io file looks as follows:
[env:trinket5]
lib_extra_dirs = ~/Documents/Arduino/libraries/Arduino_applications/Learning/libraries
board = trinket5
skuenstler:
Core 3.6.2
Yes that’s your PIO version, and it’s the most recent one (good).
Strange because it doesn’t even tyr to compile the .S
file… Can you rerun with verbosity on? Open a shell inside your IDE and type pio run -v
Here is the rerun with “verbosity” …
Okay now we have the difference.
My PIO is trying to do
i.e., avr-gcc
with the -x assembler-with-cpp
flag.
But yours is trying to use avr-as
with the exact same set of GCC flags, which won’t work. I have no idea why.
Can you please just delete the usbdrvasm.asm
file? It should still try to compile the .S
file normally.
Since I am on Windows, this might be an macOS specific problem…
NOW IT WORKS
Oh dear - how on earth would I have guessed ! Thank you very very much !
Do you know why one can delete the usbdrvasm.asm without any consequences ??
skuenstler:
NOW IT WORKS
Great. Still a macOS bug in PIO I think. @ivankravets ?
Well the header file states that this file just exists because it compiles for the IAR toolchain. Since we’re using GCC and all the file is doing is a
#include "usbdrvasm.S"
//end
I see no reason to not delete it.
Hm - educated guess…
Again, thank you very much !
Indeed, this is a bug and I’ve just fixed it in Ignore *.asm and *.ASM files when building Arduino-based library (com… · platformio/platformio-core@b874359 · GitHub
Arduino builder ignores *.asm and *.ASM files. We did the same for Arduino-based libraries.
Please set platformio-ide.useDevelopmentPIOCore
to true
in Redirecting... . Restart VSCode. Open PlatformIO IDE Terminal and type pio upgrade --dev
Does it ignore ASM files now?
@ivankravets : Thank you for your effort. However we are not there yet
After setting to true as you requested inside PIO’s settings…
…and restarting VSCode, I typed as you suggested, inside a Terminal… pio upgrade --dev
It states:
PlatformIO has been successfully upgraded to 3.6.4b1
Then I closed and re-opened VSCode.
However, I still get the very same error as before!!
I can only eliminate the error with the workaround that @maxgerhardt suggested (i.e. deleting the file usbdrvasm.asm inside the library-subfolder)…
Could you provide a simple project (archive) to reproduce this issue? You can share it on Dropbox or other services.
nyaray
June 11, 2019, 8:28pm
#17
Hi, I’m getting the same problem with the latest version of VS Code and the PIO extension, but the recommended fix works, so there’s that :).
Cheers!
majuss
March 7, 2020, 10:28am
#18
The bug is still present… however renaming the asm file to a hidden one works fine.
