I have just stumbled over the PlatformIO integration for travis-ci and was able to adapt my .travis.yml file to run with platformio.
I have to integrate my private libraries into the build.
My file structure is the following:
root
-- libraries
-- EMTB_RX
-- src
-- EMTB_RX.cpp
-- platformio.ini
-- EMTB_TX
-- src
-- EMTB_TX.cpp
-- platformio.ini
I have a general library folder for both programms, so if i make a change it effects both.
So far my .traviy.yml file is:
language: python
python:
- "2.7"
# Cache PlatformIO packages using Travis CI container-based infrastructure
sudo: false
cache:
directories:
- "~/.platformio"
env:
- PLATFORMIO_CI_SRC=EMTB_RX/src
# Do i just add the folder here? But how?
install:
- pip install -U platformio
script:
- platformio ci --board=pro8MHzatmega328
notifications:
email:
on_success: never
on_failure: never
How do i add my private libraries?
In my platformio.ini it was easy
[env:pro8MHzatmega328]
board = pro8MHzatmega328
build_flags = ${common.build_flags}
[platformio]
lib_dir = …\libraries
[common]
build_flags = -D VERSION=0.0.1
There are a few options:
- You can use
pio run command instead of pio ci, which is a wrapper around pio run when there is no platfomrio.ini. See docs Redirecting...
- You can pass extra configuration options directly from a command. See Redirecting...
Also, you can call pio ci with custom configuration. pio ci --project-conf ..... In any case, please read docs for both command. If you have platformio.ini, please use pio run.
Thank you for helping.
I already figured this out reading the docs, but it still doesn’t work.
My .travis.yml is currently
language: python
python:
- "2.7"
sudo: true
cache:
directories:
- "~/.platformio"
install:
script:
- platformio lib install
# just for understanding
- cd /home/travis/build/DiegoTheWolf/EMTB
- ls
- platformio run -d /home/travis/build/DiegoTheWolf/EMTB/EMTB_RX
notifications:
email:
on_success: never
on_failure: never
My job still not finds the libraries!
src/EMTB_RX.cpp:2:37: fatal error: RF24.h: No such file or directory
BUT in the directory im running in there is a platformio.ini file with the content:
[platformio]
lib_dir = ..\libraries
[common]
This is what i run at home without any problems.
I sync the complete repository on my PC.
Feel free to give it a look at “GitHub - DiegoTheWolf/EMTB: My try on developing a remote controll for the VESC”(DevOnline Branch)
Please be careful with PIO docs. If something is bad explained, please note here and I’ll improve. Your config should like as:
[platformio]
lib_extra_dirs = ../libraries
for adding the library, what if I had a bunch of files in a local library like this:
they are individual files, and not in separate folders for each different file name.
Now, I am having to go into every file in this library and add cpp_utils to each include statement that references any headers/files in this library folder.
Am I missing something?
[platformio]
lib_extra_dirs = ~/projectName/lib/cpp_utils
Folder Layout
lib/cpp_utils/
-file1.h
-file.cpp
-file1.h
Sorry, I don’t understand your question. cpp_utils is a library in this context. You can include it to build process via lib_deps = cpp_utils or just include any *.h file of this library in any files in your project.
Do I need to do the lib_deps and lib_extra_dirs?
Also,. I am not seeing the includes show up in the cpp_properties.json.
It took some time, but the library locations were put into cpp_properties.json file - which is cool, but only the projects that are in folders:
No, because this library is a part of project. PlatformIO looks in project/lib folder automatically.
