To_string is not a member of std
Hi to all, I’m new to platformIO and Im trying to use tensorflow lite in the esp32-CAM (using this TensorFlow Lite With Platform.io and the ESP32 - YouTube ). When I compile the program I only got his 2 errors:
error: ‘to_string’ is not a member of ‘std’.
I search in the forum for someone with this error and found this Error: 'to_string' is not a member of 'std'
But is not solved it.
I guess is something with the compiler, I’m using xtensa-esp32-elf-gcc as C/c++ compiler (by default).
Im using PlatformIO in linux tumbleweed machine.
Gastón
Interesting, I don’t even get to that point because the TensorFlow Lite library not installed
Compiling .pio/build/esp32dev/src/NeuralNetwork.cpp.o
src/NeuralNetwork.cpp:3:52: fatal error: tensorflow/lite/micro/all_ops_resolver.h: No such file or directory
Can you upload the exact tensorflow package that you’re using? I see it’s pointing at GitHub - atomic14/platformio-tensorflow-lite: Easily extract the tfmicro framework for use in platform.io but there’s quite a few configuration possibilities for tensor flow and ESP-IDF branch versions possible.
Hi maxgerhardt,
I’m using the tfmicro folder thats is generated by compiling one of the examples in the tensorflow. The only 2 errors I got is those I posted in here. I tried changing the compilers in PlatformIO but is not working.
Gastón
I have the same problem with Teensy 4.x and 3.x. On Teensy it is caused by an old version of gcc.
in the C/C++ configuration I got:
for C standard : c17
for C++ standard : c++20
compiler path: /home/gaston/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc
I tried with others path in there to solve this errors, but none of them works (clang, clang++,gcc,g++ etc)
the erros is : lib/tfmicro/tensorflow/lite/kernels/kernel_util.cc:403:19: error: ‘to_string’ is not a member of ‘std’
when i open the error in the editor this line are marked:
std::to_string(shape->data[d]);
Gaston
And with what exact command did you do that? The build is failing for me.
I have a feeling that the used tensor version, together with what C++ standardlib features it uses, greatly influences this error. That is, in conjuction with the used toolchain (toolchain-xtensa32) and C++ standard version.
Have you for fun tried the 8.4.0 toolchain instead of the standard 5.2.0 by using
platform_packages =
  toolchain-xtensa32@~2.80400.0
in the platformio.ini?
https://towardsdatascience.com/tensorflow-meet-the-esp32-3ac36d7f32c7
example to generate the tfmicro (2019) you need to change the tfmicro when you add it to the lib in the platformIO.
I tried to use
platform_packages =
but the errors still there
Gastón
Indeed when I try and compile the code
#include <string>
  std::string test = std::to_string(123);
  //should be "123" now.
  Serial.println("Test is: " + String(test.c_str()));
with
I get
Compiling .pio\build\esp32dev\src\main.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:5:22: error: 'to_string' is not a member of 'std'
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
However when I add
platform_packages =
  framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git
to the platformio.ini I get
------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.1.0) > Espressif ESP32 Dev Module
 - framework-arduinoespressif32 0.0.0+sha.371f382
 - tool-esptoolpy 1.30000.201119 (3.0.0)
 - toolchain-xtensa32 2.80400.210114 (8.4.0)
Found 32 compatible libraries
Indexing .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Building .pio\build\esp32dev\firmware.bin
Checking size .pio\build\esp32dev\firmware.elf
RAM:   [          ]   4.4% (used 14436 bytes from 327680 bytes)
Flash: [==        ]  17.3% (used 226976 bytes from 1310720 bytes)
esptool.py v3.0
================== [SUCCESS] Took 11.83 seconds ==================
so the newest compiler + Arduino core work for me and std::to_string() is available… But this is surely not how it’s supposed to work. Surely the wrong TensorFlow library version must be at use here. I hope for an update in my opened issues soon.
If i use :
platform_packages = toolchain-xtensa32@~2.80400.0 framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git
I got this error on PlatformIO:
command 'platformio-ide.build' not found
this is my platformio.ini:
[env:esp32cam]
board = esp32cam
lib_deps=tfmicro
platform_packages =
framework-arduinoespressif32@GitHub - espressif/arduino-esp32: Arduino core for the ESP32
there’s something wrong with my setup.
Gastón
P.S: funny thing, I can use platformio to program the esp32. I can’t use arduino to program the esp32 due to pyserial not found.
It’s probably doing an internal tasks rebuild and you clicked on build too fast. Try reopening VSCode and let the tasks fully reload, this may take some time due to arduino-esp32 being downloaded via git.
its working. I remove this line:
lib_deps=tfmicro
and now its working. I didn’t find an update on tensorflow with platformio, only a video (2020) and the guy who did it, din’t answer my question about those errors.
Gastón
Can you upload the whole working project for future reference for others?
sure why not. But you also was able to compile it rigth?
Gastón
No, only my minimal example with std::to_string() above, not the tensorflow example, since I can’t get the TensorFlow library to build.
I upload the file in repository GitHub (i tried to do it in here but it was to large the file).
The name is TF-ESP32-Platformio. Let me know if you are able to find it. By the way is the first repository I made, let me know if I have to add something else in there to help others.
Regards
Gastón
Yep I see it under GitHub - GastonMelo/TF-ESP32-Platformio: TensorFlow Lite With Platform.io and the ESP32 :+1:
The repository at GitHub - atomic14/tensorflow-lite-esp32: SImple example getting TensorFlow Lite up and running on the ESP32 with Platform.io has been updated and now I can build using all standard versions (normal latest release version of Arduino-ESP32, normal 5.4.0 compiler), so you should have no problems now.
