I’m experiencing an issue with the TMC2209 driver library. I’m using it to control a stepper motor with StallGuard enabled. The setup works correctly when compiled and uploaded via the Arduino IDE — the driver version returns 0x21, and StallGuard functions as expected.
However, when using the same code in PlatformIO, StallGuard does not appear to be enabled, and the device does not seem to be setup correctly(Current too high).
All of my pin configurations are defined in a separate header file, and the same codebase is used in both environments.
Could you please advise on how to resolve this issue?
Thank you.
Arduino Code
#if defined(ESP32)
SERIAL_PORT_2.begin(115200, SERIAL_8N1, RXD2, TXD2); // ESP32 can use any pins to Serial
#else
SERIAL_PORT_2.begin(115200);
pinMode(ENABLE_PIN, OUTPUT);
pinMode(STALLGUARD, INPUT);
attachInterrupt(digitalPinToInterrupt(STALLGUARD), stalled_position, RISING);
driver.begin(); // Start all the UART communications functions behind the scenes
driver.toff(4); //For operation with StealthChop, this parameter is not used, but it is required to enable the motor. In case of operation with StealthChop only, any setting is OK
driver.blank_time(24); //Recommended blank time select value
driver.I_scale_analog(false); // Disbaled to use the extrenal current sense resistors
driver.internal_Rsense(false); // Use the external Current Sense Resistors. Do not use the internal resistor as it can't handle high current.
driver.mstep_reg_select(true); //Microstep resolution selected by MSTEP register and NOT from the legacy pins.
driver.microsteps(motor_microsteps); //Set the number of microsteps. Due to the "MicroPlyer" feature, all steps get converterd to 256 microsteps automatically. However, setting a higher step count allows you to more accurately more the motor exactly where you want.
driver.TPWMTHRS(0); //DisableStealthChop PWM mode/ Page 25 of datasheet
driver.semin(0); // Turn off smart current control, known as CoolStep. It's a neat feature but is more complex and messes with StallGuard.
driver.en_spreadCycle(false); // Disable SpreadCycle. We want StealthChop becuase it works with StallGuard.
driver.pdn_disable(true); // Enable UART control
driver.rms_current(set_current);
driver.SGTHRS(set_stall);
driver.TCOOLTHRS(300);
engine.init();
stepper = engine.stepperConnectToPin(STEP_PIN);
stepper->setDirectionPin(DIR_PIN);
stepper->setEnablePin(ENABLE_PIN);
stepper->setAutoEnable(true);
stepper->setSpeedInHz(set_velocity);
stepper->setAcceleration(10000);
auto version = driver.version();
if (version != 0x21) {
Serial.println("TMC2209 driver version mismatch!");
PlatformIO
Code
#include "TMCDriverConfig.h"
#include <HardwareSerial.h>
#include "MotorControl.h"
#include <SPI.h>
#include "debug.h"
#include <TMCStepper.h>
#define SERIAL_PORT_2 Serial2
TMC2209Stepper driver(&SERIAL_PORT_2, R_SENSE, DRIVER_ADDRESS);
void initDriver() {
DEBUG_PRINTLN("Serial2 initialized for TMC2209 communication");
delay(100); // Small delay to ensure serial port is stable
driver.begin();
driver.toff(4);
driver.TPWMTHRS(0);
driver.semin(0);
// Test Communication
if(version != 0x21){
DEBUG_PRINTLN("TMC2209 driver version mismatch!");
DEBUG_PRINTLN("TMC2209 driver initialized with settings:");
DEBUG_PRINTF(" RMS Current: %d mA\n", set_current);
DEBUG_PRINTF(" Stall Guard Threshold: %d\n", set_stall);
DEBUG_PRINTF(" Coolstep Threshold: %d\n", 300);
main.cpp
// main.cpp
#include "StallGuardInterrupt.h"
initDriver(); // Initialize TMC2209 driver
initMotor(); // Initialize FastAccelStepper
setupStallInterrupt(); // Set up StallGuard interrupt
home(); // Run homing sequence
open(); // Open blinds to default position
// Empty loop — logic can go here if needed
platform.ini
board = featheresp32
teemuatlut/TMCStepper
gin66/FastAccelStepper
build_flags = -DCORE_DEBUG_LEVEL=3
