Using an old Heltec Lora v2 that comes with an
Im doing everything this guide
And im using arduinojson 7. to save in files of 1 json at a time.
Im not doing any delays or anything to give memory time to save (I dont know if this is necesary).
At some point everything I read becomes NULL and I made sure to open and close all files on each method/functions. I do have format on failure to true, but everything becomes NULL mid-run not at mounting.
Also saw this but I dont know if this is relevant
opened 09:30AM - 24 Feb 22 UTC
Area: Peripherals API
Status: Needs investigation
### Board
ESP32 Dev Module 4MB
### Device Description
The ESP32 board info:
… Board: "ESP32 Dev Module"
Upload Speed: "921600"
CPU Frequency: "240MHz (WiFi/BT"
Flash Frequency: "80MHz"
Flash Mode: "QIO"
Flash Size: "4MB (32Mb)"
Partition Scheme: "No OTA (2MB APP 2MB SPIFFS)"
Core Debug Level: "None"
PSRAM: "Disabled"
Arduino Runs On: Core1
Events Run On: Core1
Port: "COM9"
### Hardware Configuration
no external devices
### Version
v2.0.2
### IDE Name
Arduino IDE 1.8.19
### Operating System
Win10 64bit
### Flash frequency
80MHz
### PSRAM enabled
no
### Upload speed
115200
### Description
I initially posted it on forum.arduino.cc but got no replies there. Maybe that was the wrong place to post it.
I have a project in mind where I have to write sensor data into file in ESP32 flash memory (yes, I am aware of 10000 writes limit). As I understood SPIFFS is deprecated and LittleFS would be the way to go.
I decided to do a little speed test first. I uploaded the Arduino IDE ESP32 LITTLEFS_test.ino sketch onto the regular ESP32 Dev Module and added a couple of lines of code into loop to measure the append time of text "qwerty" to the file data.txt on ESP32 file system. I uploaded the file via ESP32 Sketch Data Upload tool with LittleFS, that seems to format the flash for using LittleFS.
To my great surprise the append function run time was 20-30ms in the beginning and when the data.txt file grew to a few hundred bytes it became 50-70ms. And there is very odd behavior - every 15th time the append operation takes 250-350ms. That does not depend on the append function call period. Extra long append time occurs every 15th time would the call period be 1, 2 or 3 seconds.
When I run the same script modified to use SPIFFS the append function run time is steady 5ms.
I tested the sketch on 2 different boards with the same results. I also uninstalled ESP32 boards from Arduino IDE and reinstalled. No difference.
Thank you in advance to get the LittleFS working.
### Sketch
```cpp
#include "FS.h"
#include "LittleFS.h"
#define FORMAT_LITTLEFS_IF_FAILED true
unsigned long lastAppendMillis = 0; // append function call period, ms
unsigned long beginAppendMillis = 0; // append function start time, ms
unsigned long appendMillis = 0; // append function end time, ms
void setup(){
if(!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED)){
Serial.println("LittleFS Mount Failed");
return;
Serial.println("File system info:");
Serial.print(" Total space: ");
Serial.print(LittleFS.totalBytes());
Serial.println("byte");
Serial.print(" Total space used: ");
Serial.print(LittleFS.usedBytes());
Serial.println();
listDir(LittleFS, "/", 3);
void loop(){
if (millis() - lastAppendMillis > 1000) {
lastAppendMillis = millis();
Serial.println("###########################");
Serial.println("Append qwerty");
beginAppendMillis = millis();
appendFile(LittleFS, "/data.txt", "qwerty\r\n");
appendMillis = millis() - beginAppendMillis;
Serial.print("appendMillis = ");
Serial.print(appendMillis);
Serial.println(" ms");
// LittleFS functions
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
Serial.printf("Listing directory: %s\r\n", dirname);
File root = fs.open(dirname);
if(!root){
Serial.println("- failed to open directory");
return;
if(!root.isDirectory()){
Serial.println(" - not a directory");
return;
File file = root.openNextFile();
while(file){
if(file.isDirectory()){
Serial.print(" DIR : ");
Serial.println(file.name());
if(levels){
listDir(fs, file.path(), levels -1);
} else {
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print("\tSIZE: ");
Serial.println(file.size());
void appendFile(fs::FS &fs, const char * path, const char * message){
Serial.printf("Appending to file: %s\r\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file){
Serial.println("- failed to open file for appending");
return;
if(file.print(message)){
Serial.println("- message appended");
} else {
Serial.println("- append failed");
file.close();
### Debug Message
```plain
no special debug messages
### Other Steps to Reproduce
_No response_
### I have checked existing issues, online documentation and the Troubleshooting Guide
- [X] I confirm I have checked existing issues, online documentation and Troubleshooting guide.
Suggestions on how to test memory integrity to know when it fails?
Should I use an SD card for this intead of SPI Flash? (w25q64 on HELTEC LORA V2)
Can you share a minimal example project to reproduce the error?
