TinyUSB dosent complie for ESP32-S3 (USBMIDI)
I tried to create a USB MIDI Controller using an ESP32-S3 and Platform.io as my environment instead of Arduino IDE.
While I followed the docs for the USB MIDI implementation of arduino-esp32, I realized that it does not exist (at least in the docs examples) on platform-espressif32. No Midi Controller Example there :confused:
https://github.com/espressif/arduino-esp32/blob/master/libraries/USB/examples/MIDI/MidiController/MidiController.ino
I also tried using Adafruit_TinyUSB, but when compiling, it seems it is already implemented somewhere else, leading to this error:
c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_int_enable': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:739: multiple definition of `dcd_int_enable'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:911: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_int_disable': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:743: multiple definition of `dcd_int_disable'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:917: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_remote_wakeup': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:755: multiple definition of `dcd_remote_wakeup'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:257: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_init': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:658: multiple definition of `dcd_init'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:165: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_edpt_open': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:826: multiple definition of `dcd_edpt_open'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:292: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_edpt_close_all': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:833: multiple definition of `dcd_edpt_close_all'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:370: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_edpt_xfer': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:870: multiple definition of `dcd_edpt_xfer'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:394: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_set_address': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:747: multiple definition of `dcd_set_address'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:248: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_edpt_stall': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:933: multiple definition of `dcd_edpt_stall'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:446: first defined here c:/users/marcus universe/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: .pio\build\esp32s3box\lib57d\libAdafruit TinyUSB Library.a(dcd_dwc2.c.o): in function `dcd_edpt_clear_stall': H:\Projects\Coding\ESP32\ESP32_Reciever/.pio/libdeps/esp32s3box/Adafruit TinyUSB Library/src/portable/synopsys/dwc2/dcd_dwc2.c:940: multiple definition of `dcd_edpt_clear_stall'; C:\Users\Marcus Universe\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3\lib\libarduino_tinyusb.a(dcd_esp32sx.c.obj):/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/arduino_tinyusb/src/dcd_esp32sx.c:500: first defined here collect2.exe: error: ld returned 1 exit status *** [.pio\build\esp32s3box\firmware.elf] Error 1`
My plattformio.ini:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
upload_port = COM10
build_flags = -DARDUINO_USB_CDC_ON_BOOT=1
	-DCORE_DEBUG_LEVEL=1
	-DARDUINO_USB_MODE=0
lib_archive = no
	adafruit/Adafruit NeoPixel@^1.10.4
	adafruit/Adafruit SSD1306@^2.5.11
	adafruit/Adafruit TinyUSB Library @ ^3.4.2
My current code main.ino
#include <esp_now.h>
#include <WiFi.h>
#include <USB.h>
#include <USBHIDKeyboard.h>
#include <USBHIDMouse.h>
#include <Adafruit_TinyUSB.h>
#include <MIDI.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display1(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
USBHIDKeyboard Keyboard;
USBHIDMouse Mouse;
Adafruit_USBD_MIDI usb_midi;
MIDI_CREATE_INSTANCE(Adafruit_USBD_MIDI, usb_midi, MIDI);
// Adafruit_USBD_MIDI usb_midi;
// MIDI_CREATE_INSTANCE(Adafruit_USBD_MIDI, usb_midi, MIDI);
uint8_t midiChannel = 0;
void OnDataRecv(const uint8_t *mac, const uint8_t *incomingData, int len) {
  printf("Data: %d\n", *incomingData);
  switch (*incomingData)
  case 2:
    // mouse click
    Mouse.press(MOUSE_BUTTON_LEFT);
    Mouse.release(MOUSE_BUTTON_LEFT);
    printf("mouse click\n");
    break;
  case 3:
    MIDI.sendControlChange(16, 127, 1);
    break;
  default:
    break;
#define FRAME_DELAY (42)
#define FRAME_WIDTH (48)
#define FRAME_HEIGHT (48)
#define FRAME_COUNT (sizeof(frames) / sizeof(frames[0]))
const byte PROGMEM frames[][288] = {
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,127,254,0,0,0,3,255,255,224,0,0,31,0,1,248,0,0,120,0,0,30,0,1,224,0,0,7,128,7,128,0,0,1,224,14,0,127,254,0,112,28,3,252,63,192,56,48,15,0,1,240,12,224,56,0,0,28,7,96,240,0,0,15,6,49,192,3,224,3,140,31,128,127,254,0,248,14,1,240,15,128,112,4,7,0,0,224,32,0,28,0,0,56,0,0,56,0,0,28,0,0,112,7,240,6,0,0,96,63,254,7,0,0,48,240,15,14,0,0,27,128,1,220,0,0,15,0,0,248,0,0,6,0,0,48,0,0,0,15,240,0,0,0,0,31,248,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,127,254,0,0,0,3,255,255,224,0,0,31,0,1,248,0,0,120,0,0,30,0,1,224,0,0,7,128,7,128,0,0,1,224,14,0,127,254,0,112,28,3,252,63,192,56,48,15,0,1,240,12,224,56,0,0,28,7,96,240,0,0,15,6,49,192,63,252,3,140,31,129,254,127,128,248,14,7,128,3,224,112,4,14,0,0,112,32,0,56,0,0,28,0,0,112,1,192,14,0,0,224,63,252,7,0,0,112,248,31,14,0,0,57,192,3,156,0,0,31,0,0,248,0,0,14,0,0,112,0,0,0,15,240,0,0,0,0,31,248,0,0,0,0,120,30,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,63,254,0,0,0,1,255,255,192,0,0,31,128,1,248,0,0,120,0,0,62,0,1,224,0,0,7,128,3,128,0,0,1,192,14,0,63,254,0,112,28,3,255,255,192,56,56,15,128,1,240,12,96,60,0,0,60,6,96,240,15,240,14,6,49,192,127,255,3,140,27,131,224,7,193,216,15,15,0,0,240,112,4,28,0,0,56,48,0,56,0,0,12,0,0,224,15,240,6,0,0,96,127,254,7,0,0,49,224,15,142,0,0,27,128,1,220,0,0,31,0,0,120,0,0,12,0,0,48,0,0,0,7,224,0,0,0,0,31,248,0,0,0,0,120,30,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,31,248,0,0,0,1,255,255,192,0,0,31,128,3,248,0,0,124,0,0,62,0,0,224,0,0,7,128,3,128,0,0,1,192,14,0,63,252,0,112,28,1,255,255,128,56,56,15,128,3,240,28,96,60,0,0,60,6,224,112,0,0,14,7,113,192,7,240,3,142,59,128,127,255,1,220,31,3,224,15,192,248,12,7,0,0,240,48,0,28,0,0,56,0,0,56,0,0,12,0,0,224,7,240,6,0,0,224,63,254,7,0,0,112,240,15,14,0,0,59,128,1,220,0,0,31,0,0,248,0,0,14,0,0,48,0,0,0,0,0,0,0,0,0,1,128,0,0,0,0,31,248,0,0,0,0,62,124,0,0,0,0,240,15,0,0,0,0,96,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,63,254,0,0,0,3,255,255,192,0,0,31,128,1,248,0,0,120,0,0,62,0,1,224,0,0,7,128,7,128,0,0,1,224,14,0,63,254,0,112,28,1,255,255,192,24,112,15,128,1,240,12,224,60,0,0,60,7,224,240,0,0,15,7,113,192,0,0,3,142,59,128,0,0,1,220,31,0,0,0,0,120,12,0,0,0,0,48,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,240,0,0,0,0,127,254,0,0,0,1,224,7,128,0,0,7,0,0,224,0,0,14,0,0,112,0,0,28,15,240,56,0,0,12,63,252,56,0,0,6,224,7,112,0,0,7,192,3,224,0,0,3,0,0,192,0,0,0,15,240,0,0,0,0,63,252,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,63,252,0,0,0,1,248,63,128,0,0,7,0,1,224,0,0,28,0,0,56,0,0,112,15,240,14,0,0,224,127,255,3,0,1,131,192,3,193,128,3,7,0,0,224,192,1,156,0,0,57,128,0,240,0,0,15,0,0,96,0,0,6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,7,240,0,0,0,0,28,56,0,0,0,0,127,254,0,0,0,0,255,255,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,28,120,0,0,0,0,96,134,0,0,0,0,142,113,0,0,0,0,179,197,128,0,0,0,127,255,0,0,0,0,60,60,0,0,0,0,240,15,0,0,0,0,96,6,0,0,0,0,48,12,0,0,0,0,24,24,0,0,0,0,12,48,0,0,0,0,6,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,240,0,0,0,0,63,252,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,240,0,0,0,0,31,248,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,240,0,0,0,0,49,140,0,0,0,0,95,250,0,0,0,0,255,255,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,248,0,0,0,0,255,255,0,0,0,3,192,3,192,0,0,7,0,128,224,0,0,28,31,252,56,0,0,56,240,31,12,0,0,115,128,1,206,0,0,55,0,0,252,0,0,28,0,0,56,0,0,8,0,0,16,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,240,0,0,0,0,63,252,0,0,0,0,124,62,0,0,0,0,240,15,0,0,0,0,96,6,0,0,0,0,48,12,0,0,0,0,24,24,0,0,0,0,12,48,0,0,0,0,6,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,127,254,0,0,0,3,254,127,224,0,0,31,0,0,248,0,0,120,0,0,30,0,0,224,0,0,7,0,3,128,63,252,1,192,7,1,255,255,128,224,14,7,128,3,224,112,28,30,0,0,120,56,12,120,0,0,28,56,6,224,0,0,7,112,7,192,0,0,3,224,3,128,0,0,0,192,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,128,0,0,0,0,63,252,0,0,0,0,248,31,0,0,0,1,192,3,128,0,0,3,131,224,192,0,0,3,31,248,192,0,0,1,240,15,128,0,0,0,239,247,0,0,0,0,63,252,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,63,254,0,0,0,3,255,255,192,0,0,31,128,1,248,0,0,120,0,0,62,0,1,224,0,0,7,128,7,128,0,0,1,224,14,0,63,254,0,112,28,1,255,255,192,24,112,15,128,1,240,12,224,60,0,0,60,7,224,240,0,0,15,7,113,192,0,0,3,142,59,128,0,0,1,220,31,0,0,0,0,120,12,0,0,0,0,48,0,0,15,248,0,0,0,0,255,255,0,0,0,1,224,7,192,0,0,7,0,0,224,0,0,28,0,0,48,0,0,56,7,224,28,0,0,56,63,252,12,0,0,24,252,63,24,0,0,15,192,3,248,0,0,7,128,1,240,0,0,2,0,0,96,0,0,0,0,0,0,0,0,0,15,240,0,0,0,0,63,252,0,0,0,0,112,14,0,0,0,0,224,7,0,0,0,0,112,14,0,0,0,0,56,28,0,0,0,0,28,56,0,0,0,0,14,112,0,0,0,0,7,224,0,0,0,0,3,192,0,0,0,0,1,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  Wire.begin(8, 9);
  WiFi.mode(WIFI_STA);
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
   if (!display1.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
        Serial.println(F("Error: SSD1306 allocation failed."));
        for (;;);
  esp_now_register_recv_cb(OnDataRecv);
  if (!TinyUSBDevice.isInitialized()) {
    TinyUSBDevice.begin(0);
  usb_midi.setStringDescriptor("TinyUSB MIDI");
  MIDI.begin(MIDI_CHANNEL_OMNI);
    if (TinyUSBDevice.mounted()) {
    TinyUSBDevice.detach();
    delay(10);
    TinyUSBDevice.attach();
  USB.begin();
  Keyboard.begin();
  Mouse.begin();
  Serial.println("USB HID Keyboard ready");
  display1.clearDisplay();
  display1.display();
int frame = 0;
  display1.drawBitmap(40, 8, frames[frame], FRAME_WIDTH, FRAME_HEIGHT, 1);
  display1.display();
  frame = (frame + 1) % FRAME_COUNT;
  delay(FRAME_DELAY);
I also tried using an older version of TinyUSB but nothing wanted to compile.
Is it possible to use USB MIDI on an ESP32-S3 with Platformio?
Use only the already provided lib from Arduino core. Every other lib will not work.
Thanks for the answer! :+1:
I tried to use the build in
#include "USBMIDI.h"
USBMIDI MIDI;
like described here Arduino ESP32 Github Libary Example Code: MIDI Controller, but this only works inside the Arduino IDE, not inside plattformio.
When I do this I get this error:
#include error detected. Update your includePath. Wavy lines are deactivated for this translation unit (H:\Projects\Coding\ESP32\ESP32_Reciever\src\main.ino).
The source file cannot be opened: ‘USBMIDI.h’.
Do I need to include something inside the plattform.ini file for using it? Or what will be the way for the internal Arduino Core USBMIDI? I just can’t find any examples or docs about this stuff. There are no MIDI Examples inside the[ platform-espressif32 Github.
It would be really helpful for me to know where to look. :sweat_smile:
Just to be sure you have used as platform
[env:stable]
board = ...
Examples are here arduino-esp32/libraries/USB/examples/MIDI at master · espressif/arduino-esp32 · GitHub
When I add this into the plattformio.ini its failing to install this platform:
Resolving esp32-s3-devkitc-1 dependencies...
Tool Manager: Installing https://github.com/espressif/esp32-arduino-lib-builder/releases/download/idf-release_v5.3/esp32-arduino-libs-idf-release_v5.3-cfea4f7c-v1.zip
Unpacking 0%Unpacking...
FileNotFoundError: Traceback (most recent call last):
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 37, in unpack
    return fu.unpack(dst, with_progress=with_progress)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\unpack.py", line 185, in unpack
    self._archiver.extract_item(item, dest_dir)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\unpack.py", line 49, in extract_item
    self._afo.extract(item, dest_dir)
  File "C:\Users\Marcus Universe\.platformio\python3\Lib\zipfile.py", line 1664, in extract
    return self._extract_member(member, path, pwd)
  File "C:\Users\Marcus Universe\.platformio\python3\Lib\zipfile.py", line 1735, in _extract_member
    open(targetpath, "wb") as target:
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Users\\Marcus Universe\\.platformio\\.cache\\tmp\\pkg-installing-3pdivk2p\\esp32-arduino-libs\\esp32\\include\\espressif__esp_matter\\connectedhomeip\\connectedhomeip\\src\\app\\clusters\\boolean-state-configuration-server\\BooleanStateConfigurationTestEventTriggerHandler.h'
During handling of the above exception, another exception occurred:
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\__main__.py", line 103, in main
    cli()  # pylint: disable=no-value-for-parameter
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1157, in __call__
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1078, in main
    rv = self.invoke(ctx)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\cli.py", line 85, in invoke
    return super().invoke(ctx)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1688, in invoke
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1434, in invoke
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 783, in invoke
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\project\commands\init.py", line 106, in project_init_cmd
    install_project_dependencies(
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 107, in install_project_dependencies
    already_up_to_date = not install_project_env_dependencies(env, options)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 132, in install_project_env_dependencies
    _install_project_env_platform(project_env, options),
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 149, in _install_project_env_platform
    PlatformPackageManager().install(
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\manager\platform.py", line 62, in install
    p.install_required_packages(force=force)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py", line 76, in install_required_packages
    self.install_package(name, force=force)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py", line 70, in install_package
    return self.pm.install(spec or self.get_package_spec(name), force=force)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 47, in install
    pkg = self._install(spec, skip_dependencies=skip_dependencies, force=force)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 97, in _install
    pkg = self.install_from_uri(spec.uri, spec)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 191, in install_from_uri
    self.unpack(dl_path, tmp_dir)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 42, in unpack
    return fu.unpack(dst, with_progress=False)
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\platformio\package\unpack.py", line 178, in unpack
  `python -m pip install -U platformio` command
I verified that this python -m pip install -U platformio is installed. Is there a different way to install it?
Your Platformio setup is broken. Close VSC. Delete the hidden folder .platformio and delete in your project folder every build folder and from Platformio generated folder. Start VSC, wait and follow instructions. After this Platformio should work again and compile the example.
I did this and on top of that even did "pip uninstall platformio" , python -m pip uninstall platformio, disabled antivirus according to the pioarduino docs, deleted the folders you mentioned and reinstalled vscode and the extension.
Then I tried on 2 different pcs to reinstall it. I followed these steps: Installer Script (Recommended) — PlatformIO latest documentation
But every time it grabs the plattformio.ini it still spits the same error on both machines.
Error Message:
Platform Manager: Installing https://github.com/pioarduino/platform-espressif32/releases/download/53.03.10/platform-espressif32.zip
Unpacking 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
Platform Manager: espressif32@53.3.10 has been installed!
Tool Manager: Installing https://github.com/espressif/arduino-esp32/releases/download/3.1.0/esp32-3.1.0.zip
Tool Manager: framework-arduinoespressif32@3.1.0 has been installed!
Tool Manager: Installing https://github.com/espressif/esp32-arduino-lib-builder/releases/download/idf-release_v5.3/esp32-arduino-libs-idf-release_v5.3-083aad99-v2.zip
  File "C:\Users\Marcus Universe\AppData\Local\Programs\Python\Python312\Lib\zipfile\__init__.py", line 1726, in extract
  File "C:\Users\Marcus Universe\AppData\Local\Programs\Python\Python312\Lib\zipfile\__init__.py", line 1801, in _extract_member
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Users\\Marcus Universe\\.platformio\\.cache\\tmp\\pkg-installing-3o212r5f\\esp32-arduino-libs\\esp32\\include\\espressif__esp_matter\\connectedhomeip\\connectedhomeip\\src\\app\\clusters\\boolean-state-configuration-server\\BooleanStateConfigurationTestEventTriggerHandler.h'
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1161, in __call__
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1082, in main
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1697, in invoke
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 1443, in invoke
  File "C:\Users\Marcus Universe\.platformio\penv\Lib\site-packages\click\core.py", line 788, in invoke
Current plattformio.ini:
platform = https://github.com/pioarduino/platform-espressif32/releases/download/53.03.10/platform-espressif32.zip
upload_port = COM10
build_unflags =
  -DARDUINO_USB_MODE
    -DARDUINO_USB_MODE=1
lib_archive = no
When I use:
it works fine, but #include <USBMIDI.h> is not available.
Is there a way to fix this issue or a manual way to install it?
Thanks for all your help so far.:pray:
Never use whitespaces in Path with Platformio
By reinstalling the extension on a new user without spaces inside the name, im getting not this error anymore and my USBMIDI code compiled successfully.
Thanks a lot for the help :+1:
