I installed the Timer1 library and tried this code :
#include <TimerOne.h>
String ledStatus = "OFF";
int blueLED = 6;
int greenLED = 5;
pinMode(blueLED, OUTPUT);
pinMode(greenLED, OUTPUT);
Timer1.initialize(1000000);
Timer1.attachInterrupt(blinkGreen);
digitalWrite(blueLED, HIGH);
delay(250);
digitalWrite(blueLED, LOW);
delay(250);
void blinkGreen() {
if (ledStatus == "ON") { // Start of if1 loop
digitalWrite (greenLED, LOW);
ledStatus = "OFF";
return; // leave this function --> void blinkGreen and return to the main code --> void loop
} // End of if1 loop
if (ledStatus == "OFF") { // Start if2 loop
digitalWrite(greenLED, HIGH);
ledStatus = "ON";
return;
} // End if2 loop
when uploading it I get this error :
src/main.cpp: In function âvoid setup()â:
src/main.cpp:14:26: error: âblinkGreenâ was not declared in this scope
*** [.pioenvs/nanoatmega328/src/main.cpp.o] Error 1
========================== [ERROR] Took 5.76 seconds ==========================
Linter
Severity Provider Description Line
Error GCC âblinkGreenâ was not declared in this scope 14:26
Error Build error: âblinkGreenâ was not declared in this scopee 14:26
PIO Buildsrc/main.cpp20040:1(39, 759)
LFUTF-8C++0 files
And the same code works flawlessly if uploaded using Arduino IDE
What could be wrong?
Put blinkGreen function above setup().
Or add a declaration: void blinkGreen(); above setup().
This is done implicitly by Arduino IDE.
Thank you a million
I added the line void blinkGreen( ); before void setup ( ) and now It is working flawlessly
Thanks again
I might be a bit of a noob here, but isnât it pretty standard for any ANSI C derivative languages to allow the functions to be pretty much anywhere in the file, and have the compiler still find them?
As fair as I understood; the Arduino framework is just a bunch of libraries on top of C++, so it seems a bit odd to me that we need to put ISR defs above setup(). Also by my interweb suggests that the people using the vanilla Arduino IDE (gcc IIRC) arenât having this problem.
Could someone please clarify whatâs going on, or point me to what Iâm missing? Is this simply a âgcc vs Visual Studioâ thing, or some kind of an ANSI-compliance thing?
Thanks,
Nrrdzilla
No, itâs not.
You can put them anywhere in the file if you first declare their existence before they are used for the first time. If the compiler doesnât know about the existence of the function before it encounters itâs first use, it will spit the dummy.
The Arduino IDE has a preprocessor system (Arduino builder) which does things in a non-C/C+±standard manner - such as generating function prototypes itself, and mashing all the open tabs in a sketch together, making it a single file.
Itâs just easier to shove the setup and loop at the end of the file, then you donât need to declare prototypes at all since theyâll have all defined by the time they are called in setup or loop.
Should be Timer1.attachInterrupt(&blinkGreen);
