Hello guys,
I am taking advantage of the time at home to play with my ESP32. But I ran into a problem.
I am making a program with WiFi events and interrupt with timer. The programs individually work well but when joining them the program shows the following error and restarts all the time.
Guru Meditation Error: Core 1 panic’ed (Cache disabled but cached memory region accessed)
Core 1 register dump:
PC : 0x400d10bc PS : 0x00060034 A0 : 0x80081048 A1 : 0x3ffbe790
A2 : 0x3ffbec00 A3 : 0x20000000 A4 : 0x00000400 A5 : 0x3ffbe790
A6 : 0x3ffbe7d8 A7 : 0x00000001 A8 : 0x80080f4d A9 : 0x00000001
A10 : 0x00060223 A11 : 0x00000000 A12 : 0x8008a40b A13 : 0x3ffbe760
A14 : 0x00000008 A15 : 0x00000001 SAR : 0x0000001e EXCCAUSE: 0x00000007
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Core 1 was running in ISR context:
EPC1 : 0x40086ab9 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x400d10bc
Backtrace: 0x400d10bc:0x3ffbe790 0x40081045:0x3ffbe7b0 0x40084809:0x3ffbe7d0 0x40086ab6:0x3ffba190 0x40082c23:0x3ffba1b0 0x40088c15:0x3ffba1d0
and my test program is as follows
#include <WiFi.h>const char* ssid = “yourNetworkName”;
const char* password = “yourNetworkPass”;
hw_timer_t * timer = NULL;
uint32_t cnt=0;void test();
void IRAM_ATTR onTimer();
void WiFiEvent(WiFiEvent_t event);void setup()
Serial.begin(115200);timer = timerBegin(0, 80, true);
timerAttachInterrupt(timer, &onTimer, true);
timerAlarmWrite(timer, 1358, true);
timerAlarmEnable(timer);WiFi.onEvent(WiFiEvent);
WiFi.begin(ssid, password);
}void loop(){}
void test(){cnt++;}
void IRAM_ATTR onTimer() {
test();
}void WiFiEvent(WiFiEvent_t event){
Serial.printf("[WiFi-event] event: %d\n", event);
switch (event){ //Obtiene evento wifi
case SYSTEM_EVENT_WIFI_READY:
Serial.println(“WiFi interface ready”);
break;
case SYSTEM_EVENT_SCAN_DONE:
Serial.println(“Completed scan for access points”);
break;
case SYSTEM_EVENT_STA_START:
Serial.println(“WiFi client started”);
break;
case SYSTEM_EVENT_STA_STOP:
Serial.println(“WiFi clients stopped”);
break;
case SYSTEM_EVENT_STA_CONNECTED:
Serial.println(“Connected to access point”);
break;
case SYSTEM_EVENT_STA_DISCONNECTED: //Evento de desconexión STA
Serial.println(“Disconnected from WiFi access point”);
break;
case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:
Serial.println(“Authentication mode of access point has changed”);
break;
case SYSTEM_EVENT_STA_GOT_IP:
Serial.print("Obtained IP address: ");
break;
case SYSTEM_EVENT_STA_LOST_IP:
Serial.println(“Lost IP address and IP address is reset to 0”);
break;
case SYSTEM_EVENT_STA_WPS_ER_SUCCESS:
Serial.println(“WiFi Protected Setup (WPS): succeeded in enrollee mode”);
break;
case SYSTEM_EVENT_STA_WPS_ER_FAILED:
Serial.println(“WiFi Protected Setup (WPS): failed in enrollee mode”);
break;
case SYSTEM_EVENT_STA_WPS_ER_TIMEOUT:
Serial.println(“WiFi Protected Setup (WPS): timeout in enrollee mode”);
break;
case SYSTEM_EVENT_STA_WPS_ER_PIN:
Serial.println(“WiFi Protected Setup (WPS): pin code in enrollee mode”);
break;
case SYSTEM_EVENT_AP_START:
Serial.println(“WiFi access point started”);
break;
case SYSTEM_EVENT_AP_STOP:
Serial.println(“WiFi access point stopped”);
break;
case SYSTEM_EVENT_AP_STACONNECTED:
Serial.println(“Client connected”);
break;
case SYSTEM_EVENT_AP_STADISCONNECTED:
Serial.println(“Client disconnected”);
break;
case SYSTEM_EVENT_AP_STAIPASSIGNED:
Serial.println(“Assigned IP address to client”);
break;
case SYSTEM_EVENT_AP_PROBEREQRECVED:
Serial.println(“Received probe request”);
break;
case SYSTEM_EVENT_GOT_IP6:
Serial.println(“IPv6 is preferred”);
break;
case SYSTEM_EVENT_ETH_START:
Serial.println(“Ethernet started”);
break;
case SYSTEM_EVENT_ETH_STOP:
Serial.println(“Ethernet stopped”);
break;
case SYSTEM_EVENT_ETH_CONNECTED:
Serial.println(“Ethernet connected”);
break;
case SYSTEM_EVENT_ETH_DISCONNECTED:
Serial.println(“Ethernet disconnected”);
break;
case SYSTEM_EVENT_ETH_GOT_IP:
Serial.println(“Obtained IP address”);
break;
default:
break;
is there any way to fix it?
Thanks
