Hi
I have a nodeMcu card and running VS Code with PlatformIO.
Trying to set up a small scheduler and would like to use this version of Ticker
( Arduino/libraries/Ticker at master · esp8266/Arduino · GitHub ).
The compiler cant find Ticker.h.
Whats wrong ??
platform.ini
[global]
lib_deps=
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
lib_extra_dirs = ../../library
lib_ignore =
lib_ldf_mode = deep+
monitor_port = COM4
Works for me
main.cpp
#include <Ticker.h>
Ticker flipper;
int count = 0;
void flip() {
int state = digitalRead(LED_BUILTIN); // get the current state of GPIO1 pin
digitalWrite(LED_BUILTIN, !state); // set pin to the opposite state
++count;
// when the counter reaches a certain value, start blinking like crazy
if (count == 20) {
flipper.attach(0.1, flip);
// when the counter reaches yet another value, stop blinking
else if (count == 120) {
flipper.detach();
pinMode(LED_BUILTIN, OUTPUT);
// flip the pin every 0.3s
flipper.attach(0.3, flip);
platformio.ini
[env:esp8266]
board = nodemcuv2
DATA: [==== ] 35.2% (used 28796 bytes from 81920 bytes)
PROGRAM: [== ] 24.7% (used 257628 bytes from 1044464 bytes)
[SUCCESS] Took 11.43 seconds
I changed my plattform.ini to match yours … => no luck.
Then I looked at
c:.platformio\lib\ and found a another “ticker” library
When I removed that it all worked fine.
Just a note, from VS Code PlatformIO IDE, no external library is installed. So something is mixed up here.
