I need to load the elf image at 0x1000 in flash, not 0x0.
This is my application code at 0x1000 and my loader is at 0x0.
So I need to be able to set the load address is flash for each part.
I am doing this in CCS, with the mem.ld file.
Would be very nice to use platformio instead of CCS.
CCS file to control flash location
* lm4fcpp.ld - Linker configuration file for Energia c++ programs.
MEMORY
/* pick the right one here
flash (rx) : ORIGIN = 0x00000000, LENGTH = 0x00030000
flash (rx) : ORIGIN = 0x00030000, LENGTH = 0x00010000
ram (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00008000
flash (rx) : ORIGIN = 0x00010000, LENGTH = 0x00030000
/* STACK_SIZE = DEFINED(STACK_SIZE) ? STACK_SIZE : 0x1000 ; */
REGION_ALIAS("REGION_TEXT", flash);
REGION_ALIAS("REGION_RAM", ram);
SECTIONS
.text :
. = ALIGN(4);
_text = .;
KEEP(*(.isr_vector))
*(.text .text* .gnu.linkonce.t.*)
*(.glue_7t) *(.glue_7)
*(.rodata .rodata* .gnu.linkonce.r.*)
*(.ARM.extab* .gnu.linkonce.armextab.*)
. = ALIGN(4);
KEEP(*(.init))
. = ALIGN(4);
__preinit_array_start = .;
KEEP (*(SORT(.preinit_array*)))
KEEP (*(.preinit_array))
__preinit_array_end = .;
. = ALIGN(4);
__init_array_start = .;
KEEP (*(SORT(.init_array.*)))
KEEP (*(.init_array))
__init_array_end = .;
. = ALIGN(4);
KEEP(*(.fini))
. = ALIGN(4);
__fini_array_start = .;
KEEP (*(.fini_array))
KEEP (*(SORT(.fini_array.*)))
__fini_array_end = .;
. = ALIGN(4);
_etext = .;
} > REGION_TEXT
.data : AT(ADDR(.text) + SIZEOF(.text))
. = ALIGN(4);
_data = .;
*(vtable)
*(.data .data* .gnu.linkonce.d.*)
_edata = .;
} > REGION_RAM
.bss (NOLOAD):
. = ALIGN(4);
_bss = .;
*(.bss .bss*)
*(COMMON)
. = ALIGN(4);
_ebss = .;
. = ALIGN(8);
} > REGION_RAM
.stack (NOLOAD):
. = ALIGN(8);
_stack = .;
. = . + STACK_SIZE;
. = ALIGN(8);
_estack = .;
} > REGION_RAM
PROVIDE_HIDDEN (__exidx_start = .);
.ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > REGION_RAM
PROVIDE_HIDDEN (__exidx_end = .);
. = ALIGN(4);
_end = . ;
/* end of allocated ram is start of heap, heap grows up towards stack*/
PROVIDE(end = _end);
/* top of stack starts at end of ram, stack grows down towards heap */
PROVIDE (_estack = ORIGIN(ram) + LENGTH(ram));
Thanks for the help
